Installing haltech PPP
Old Jul 20, 2012 | 04:51 AM
kaissi's Avatar
Default Installing haltech PPP
Hello, I just got my Haltech PPP installed,
main issues so far: longer cranking time for the engine to start compared to stock!!
http://www.youtube.com/watch?v=N8Ji3...ature=youtu.be
Are the sensors reading fine?
Old Jul 20, 2012 | 08:57 AM
b.r.i.a.n.'s Avatar
the link isn't there. it most likely has to do with the prime pulse time table.
Old Jul 20, 2012 | 09:26 AM
tx2K's Avatar
Does the haltech usually start like stock when tuned right or is this just like the AEM where it always requires several turns to fire?
Old Jul 20, 2012 | 09:38 AM
kaissi's Avatar
www.youtube.com/watch?v=N8Ji3PE9Mdg
Old Jul 20, 2012 | 01:50 PM
b.r.i.a.n.'s Avatar
it should be able to start somewhat like stock if you take the time to tune it.
that's actually not that bad for a cold start. i may need some more fuel. i'd try adding fuel to the prime pulse time table first. do you have a wideband or are you still using the stock narrowband?
Old Jul 20, 2012 | 05:00 PM
kaissi's Avatar
http://www.youtube.com/watch?v=N8Ji3PE9Mdg
Brian:
I have the AEM UEGO wideband, I'll hook it to the auxiliary port of the Haltech soon and let you know
The thing is, I was trying to make sure everything is reading fine, for I have a bad history with AEM EMS 2 on Euro S2000. I got fuzzy readings, I couldn't do anything at all.
So I think so far I'm fine, I can proceed to put the wideband, and do some runs with the logs.
Old Jul 21, 2012 | 02:57 PM
b.r.i.a.n.'s Avatar
Brian:
everything seems fine. just double check base timing, hook up the wideband and you can start tuning.
Old Oct 2, 2013 | 10:22 PM
owenxguo's Avatar
quick question here, which wire on auxiliary harness is for wide band signal use? I might wired it wrong just wanna double check.
teamvalorracing
Feb 14, 2012 03:21 PM
anarchy187
Oct 11, 2011 09:49 AM
rikhemi
Nov 9, 2010 02:50 PM
