Kpro on a 07 S2000?!
Old Jan 10, 2015 | 07:38 AM
turbodreamz22's Avatar
Default Kpro on a 07 S2000?!
Hey guys
I plan on BOOSTING a 07 S2K, and I want to be able to pass emissions where I live in MA. So I want to run Kpro for the ability to do that.
So I was on the Hondata site to read up exactly what would be needed to swap over to run kpro on a 07 s2000. Now they gave a list of all the things needed to swap over for it to work and stuff, but at the bottom of the page I saw this
Now you can see it saying 2006-2007 s2000: RSX ECU is not compatible with the 06-07 drive by wire so you can't use kpro. Sorry
So I may be confused because at the top of the site is says what's needed to swap on a 06-07 to run the kpro. But down at the bottom of the page it says that.
Can someone chime in for me. If you swap every thing Hondata says to swap over on their page will the kpro work on a 06+ s2000
Thank you
Old Jan 10, 2015 | 07:50 AM
1nate7's Avatar
I'd say that is a fairly clear statement that it won't work. This may be a stupid question, but why wouldn't you just use Flashpro?
Old Jan 10, 2015 | 07:55 AM
Well I plan on boosting the car and want to be able to pass emissions still. And I don't want to run aem and go
Thru the hassle.
So my option was to run kpro. To have the ability to pass emissions sill.
Old Jan 10, 2015 | 07:56 AM
I fixed my openening state to clarify what in looking for. Sorry for any misunderstanding.
Old Jan 10, 2015 | 08:51 AM
1nate7's Avatar
Luckily for you, 06+ can use Flashpro to accomplish everything you want. It's cheaper and easier to use by simply reflashing the ECU through the ODBII port.
http://www.hondata.com/flashpro.html
Old Jan 10, 2015 | 09:18 AM
And flash pro allows the car when boosted to pass the emissions?
Thank you
Old Jan 10, 2015 | 09:23 AM
DaGou's Avatar
Thank you
Yes flashpro allows you pass emissions. I do not understand why you think otherwise. Or why you think you can pass with kpro and not flashpro.
Old Jan 10, 2015 | 09:41 AM
Originally Posted by DaGou
Originally Posted by turbodreamz22' timestamp='1420913929' post='23463209
[quote name='1nate7' timestamp='1420912266' post='23463190']
Thank you
[/quote]
I just wanted to clarify. I'm used to owning EVO's and STI's where all I would need is the tactrix cable and the open source program. So having to swap to a separate style ecu is new to me. I just wanted to clarify things
Thank you.
Old Jan 10, 2015 | 09:55 AM
Memo6453's Avatar
Flashpro FTW on DBW not sure where the confusion is at.
and you dont need to ask on 4 diff threads one of which was from 2011 lol
Old Jan 10, 2015 | 01:03 PM
DaGou's Avatar
Originally Posted by DaGou' timestamp='1420914187' post='23463212
[quote name='turbodreamz22' timestamp='1420913929' post='23463209']
Thank you
[/quote]
Thank you.
[/quote]
NOt swapping ECU just reflash you existing ECU with FlashPro. Catchy name uh, flash with flash pro. If you asked in 4 threads starting in 2011 you are a dick and I am wasting my time helping dicks. If not I hope this clears things up for you.
leas2000
Κινητήρας - Μετάδοση - Περιφερειακά
Oct 31, 2013 04:29 AM
energetic
Συναντήσεις και εκδηλώσεις
29
Jul 14, 2009 11:40 AM
wuchan01
Florida For Sale
May 20, 2008 04:42 PM
energetic
267
Jan 3, 2008 11:50 PM
energetic
17
Oct 17, 2007 04:33 AM
