kpro for s2k?
Old Oct 31, 2012 | 03:57 PM
danielcrx's Avatar
Default kpro for s2k?
Is there a kpro setup for a s2000??? Or something like that?? Thanks
Old Oct 31, 2012 | 07:27 PM
Mini-Ch0pper's Avatar
Hondata makes the K-Pro for ap1s and FlashPro for ap2s. If you buy the K-Pro kit for an ap1, there's about $320 extra in oem Honda parts you'll need to buy to make the K series ECU compatible with the F20c.
K-Pro - Hondata.com
Old Oct 31, 2012 | 07:34 PM
Trackforged's Avatar
Former Sponsor
K-Pro - Hondata.com
Actually K-pro is for 04/05 AP2's and AP1's Flashpro is for 06+ only
Evan
Old Feb 4, 2013 | 10:13 AM
s2000maniac's Avatar
go to the Hondata website, they have all the parts listed.
Old Feb 23, 2013 | 08:10 AM
NYS2000TURBO's Avatar
im going to be selling my brand new in the box kpro setup with all the supporting mods to make it work with Ap1. Everything is brand new. Selling because im doing the K24 swap and this ecu isnt compatible.
Old Feb 23, 2013 | 08:17 AM
westfield147's Avatar
why isnt it compatible with the k24 swap? When you say k24 swap, do you mean crank-ie stroker kit? I thought this kit could be used for stroker kits aswell as turbo/supercharger ones?
Old Feb 23, 2013 | 10:39 AM
JUSTINTHECOASTIE's Avatar
Because he might can use flashpro instead
Old Feb 23, 2013 | 11:10 AM
I'm installing a complete k24 engine. Not swapping out internals into my f20. It's a completely built 2.4l TSX motor. I actually don't know if I can use flash pro. Any insight on that anyone? My car is an '01 Ap1.
Old Feb 23, 2013 | 02:05 PM
What year is your k24? Also check this out http://www.hondata.com/flashpro_tsx.html
Even if you have a 04-06 motor, you can still use flashpro if you use the adapter, and 08 ecu(buy used)
Old Feb 23, 2013 | 03:01 PM
rus21s's Avatar
I would buy a spoon ecu for the AP1.
