kpro for s2k?
Old Feb 23, 2013 | 06:16 PM
JUSTINTHECOASTIE's Avatar
Originally Posted by rus21s
I would buy a spoon ecu for the AP1.
Depends. Those type of ecus are limited, and are funny unless you have specific supporting mods. Very difficult to build on if going further into na or even transferring to boost.
Old Feb 25, 2013 | 03:18 PM
Realistically, find a reputable tuner and run what he/she is comfortable with tuning due to my wedding, my kpro is on hold and I'm probably going to use AEM
Old Mar 17, 2013 | 10:45 AM
leo520's Avatar
If u can go with aem,go with aem instead of k-pro.
I had k-pro in my dbw s2000.it's dual ecu. I am regretted every second right now.
Lack of suppory,k-manager didn't fully functions.
Made all my sensors unsupported, can't pass emissions.
Old Mar 20, 2013 | 02:37 PM
Why didn't you just do flashpro?
Old Mar 20, 2013 | 07:39 PM
limbo's Avatar
http://lmgtfy.com/?q=Kpro+s2000
Old Mar 28, 2013 | 09:01 AM
2d-ink's Avatar
Originally Posted by NYS2000TURBO
I'm installing a complete k24 engine. Not swapping out internals into my f20. It's a completely built 2.4l TSX motor. I actually don't know if I can use flash pro. Any insight on that anyone? My car is an '01 Ap1.
When your doing the K24 swap into your AP1 you will use RSX-S charge harness and main harness and run a sub harness to connect it to your dash/body. since your using a RSX harness you will need to use RSX ECU so the K-Pro ecu will work. when doing the K24 swap the two ecu you can only us are AEM EMS or K-pro. Best of luck
Old Apr 3, 2013 | 10:53 AM
spectacle's Avatar
It probably wasn't out then.
Old Apr 9, 2013 | 04:29 AM
Forcedbird's Avatar
Originally Posted by spectacle
Originally Posted by JUSTINTHECOASTIE' timestamp='1363819024' post='22417098
[quote name='leo520' timestamp='1363545951' post='22409477']
[/quote]
^ correct
Old Jun 20, 2013 | 09:03 AM
leo520's Avatar
Originally Posted by Forcedbird
Originally Posted by spectacle' timestamp='1365015202' post='22448853
[quote name='JUSTINTHECOASTIE' timestamp='1363819024' post='22417098']
[/quote]
^ correct
[/quote]
That's right..i Can't drive the car now.
No inspection sticker
Old Jun 20, 2013 | 09:45 AM
waleed786's Avatar
Pretty sure the main reason for flashpro vs kpro is the drive by wire. Kpro does not support drive by wire, flashpro dies. So the k24 swap would depend on what year tsx it came out of, I believe the early ones had a throttle cable.
