Kpro V4 fluctuating idle
I am trying to figure out a fluctuating idle issue with 01 s2000 with kPro V4.
I've attached the datalog for the s2000. The idle is high at 2k, and will fluctuate between 1-2k repeatedly, when i turn on the AC it'll stop the fluctuating, but idle will remain high at 2k rpm. Any help would be appreciated.
I've attached the basemap i'm using as well as the datalog showing the fluctuations.
https://drive.google.com/open?id=1eM...WRknEP3H8NQyWl
https://drive.google.com/open?id=1qs...BlNqOJxTkHsiNi
Thanks,
Sheng
Thanks,
Sheng
For some reason you are dropping out of closed loop, this is when your fluctuations occurs.
Is your MAP sensor scaled correctly? I see you don't use the stock one, but if you still got that one might try to swap it in.
Getting a wideband installed to see more what's going on would really help as well.
Intake temps seems very high also, is that reading correct?
What's wrong with the TPS setup?
It's reading 0% almost all the time even though it's switching between open/closed loop so doesn't seem to be the problem.
Sheng: I'm guessing you did touch the throttle a few times during the log?
How gay is that !!
