Kpro V4 and gauges help
I currently have Kpro V4 on my turbo setup. I run a dual gauge pod with aem boost/wideband.
I am wondering if it's possible to display the gauges on my phone instead of using the gauges in the pods? Or do the sensors need to relay information through the gauge and then back to the ECM in order to work. Basically I want to directly wire the sensors to ECM without using the display. Just not sure if it's possible.
I would like to end up with fuel pressure/boost/wideband/oil pressure all displayed on my phone.
I have a PLX wideband with my KPro4 and display it via their phone App. I do have the PLX gauge but its not required since KPro4 uses it for data logging as well. You assign the wideband for AF and you are good to go. I cannot speak for AEM stuff but at least you know its possible.
I would checkout their forums to be sure but it should since KPro4 supports all of that now and all you do is assign it.
https://www.hondata.com/mobile
Hey blixhavn I am running my PLX wideband as primary O2 with no other primary. It's wired via analog input an it displays via phone app no problem.
I believe if you replace existing sensors that KPro show such as AF vs oil pressure then your ok. You can't add anything to phone app as of yet though is what I suspect. Again this would need to be clarified.
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
Thanks Flanders for the comment. The Bosch sensor is super reliable to use and cost effective so its a win win being that the accuracy is higher and overall quality. PLX even has a health feature and can tell when its close to replacement time based off how quick the O2 responds. Tech is getting really good. Also as a fail safe I do have the stock sensor plugged up just in case and then I just update KPro accordingly.
