need help
Old Feb 13, 2011 | 03:13 PM
azride1983's Avatar
Default need help
which AFr would you look at? the AF. corr or the AF by itself?
and anyone here with supercharger that uses the launch control?
how do you tune by ignition timing or a/f ratio?
Old Feb 14, 2011 | 07:37 AM
Gernby's Avatar
Former Sponsor
I look at both AF values to make sure both are within a "safe" range, but target whatever actual value yields best power.
Launch control should work just the same for NA as with an SC, since that's mostly about the surface, tires, clutch, and flywheel.
Your last question would take a book.
Old Feb 16, 2011 | 12:14 PM
azride1983's Avatar
how do you know the tune is going the right way? is there some kind of graph that shows you the gain? or i got to do this on the dyno?
Old Feb 16, 2011 | 03:44 PM
H22toF20's Avatar
My advise would to read some Engine Management books before you even attempt to mess with anything; especially timing.
Old Feb 16, 2011 | 07:23 PM
INTJ's Avatar
Old Feb 17, 2011 | 01:39 PM
Gernby's Avatar
Former Sponsor
It's easier to tell if the tune is going the wrong way than the right way. Basically, if you make a small change without knowing what you're doing and blow your motor, then you know it's going wrong.
randy!
Nov 25, 2009 07:18 PM
LostMotion
May 14, 2009 07:48 AM
scutrCR
Tampa
25
Mar 10, 2009 09:44 AM
tagheuer
Apr 1, 2005 09:03 AM
HJZ
32
Jul 28, 2004 01:55 AM
