New Kpro version 1.4.5 beta released
Old Feb 3, 2011 | 06:44 AM
spectacle's Avatar
Default New Kpro version 1.4.5 beta released
http://hondata.com/forum/viewtopic.php?t=1...der=asc&start=0
I haven't had a chance to try it out yet but if you run through the changelog you'll see that this brings Kpro right up to the lines of capability currently present in FlashPro. Notable standouts:
- KNOCK CONTROL
- Datalog AutoSave
- Revert to last Save
- Import from Calibration (copying tables from one calibration to another)
- Closed Loop Target Lambda
As far as functionality, there is also some additional Lamda target tables released also. Unfortunately, most of us can't use them because they rely on the stock wideband o2 from the RSX to be able to use them. I'm going to inquire about the possibility of them incorporating the ELD input as a data source replacement for the stock wideband. They may be open to it depending on how complex the coding would have to be. Without that, a lot of the cool things the Kpro can do are pretty lost on the S2000 (lean cut, closed loop target lamda).
Old Feb 3, 2011 | 06:52 AM
DFWs2k's Avatar
yea i saw this yesterday, luckily i have an rsx wideband waiting to go in
Old Feb 3, 2011 | 07:28 AM
Gernby's Avatar
Former Sponsor
I haven't ever been able to make the closed loop target lambda feature do anything with my FlashPro. I suspect it's a dummy table.
Old Feb 3, 2011 | 09:33 AM
nnausmann's Avatar
- KNOCK CONTROL
- Datalog AutoSave
Sweet glad I run the RSX wideband.
Old Feb 3, 2011 | 03:10 PM
b.r.i.a.n.'s Avatar
these are the same knock control tables that were exposed on the flashpro software last year.
it works ok with your typical bolt on's but once you go past that it sucks. i just zero out the knock ignition limit tables so that i don't get knock retard what so ever.
Old Feb 6, 2011 | 11:18 AM
spectacle's Avatar
Just got the new version going. It jacked up my tunerview so I can't give much feedback as of yet. There is definitely a lot of new tables to learn though. I'm excited to dig into them
Old Feb 6, 2011 | 11:31 AM
Gernby's Avatar
Former Sponsor
That's one of the reasons why I love the FlashPro. It's like getting another cool toy for free whenever Hondata adds a new feature.
Old Feb 8, 2011 | 07:39 AM
Kyushin's Avatar
Banned
Purge system? Are they referring to the evap system?
Old Jun 1, 2011 | 03:20 PM
Kyushin's Avatar
Banned
How does Kpro tell you knock was detected, would it give a blinking CEL like OEM and throw a code associated?
I was doing a hard pull the other day and the cel flickered, it wasnt the rapid blink like a mis fire, but just an odd flicker for a split second or two
Old Jun 1, 2011 | 03:39 PM
DFWs2k's Avatar
tells you in datalogs, i think you can have it blink on knock
