No VTEC with stock ECU
Posting here to add to the knowledge base.
I have a F20C running on a stock ECU in my race car.
At my last race meeting I noticed the car starting to get intermittent vtec, which quickly degraded into no VTEC with the bonus that it would fall into limp home mode if I tried to drive it > 6500rpm.
I thought it could have been because of an overvoltage as i had my kill switch play up in the same session the problem started.
I replaced the knock sensor and whole vtec switching assembly and check the wiring, then I cracked open the ECU.
It wasn't due to the bad kill switch. Just a coincidence.
The problem was that the VTEC switching IC ( a specially packaged transistor setup) is standing free from the main circuit board with nothing supporting it. Under race conditions in the orientation that I had the ECU mounted the long term vibration caused brittle fatigue of the components legs causing two to break.
I traced the problem to an open circuit on this component. It wasn't till I started to desolder it I found the two legs that had brittle fatigued. It was almost impossible to see until I got some heat onto the solder joints on the circuit board.
The component was SK5151S and was available from an online seller in the US for $7 plus $3 postage.
Have now mounted the ECU with rubber vibration isolaters, and used a hot glue gun to tie the component to the one next to it , and to the circuit board at its base.
Hopefully this is a rare problem, hopefully this info will help someone who has the same symptoms.
Originally Posted by 96-EJ6,May 21 2010, 07:13 PM
Wow, great failure anaylisys. Good info, thank you.
You don't have the ECU mounted in the stock location?
