TPS/Tplate tuning
Old May 24, 2010 | 03:17 PM
whiteflash's Avatar
Default TPS/Tplate tuning
So during logs I've noticed my tpedal and tplate being entirely different values. Any reason for this? Is the throttle plate independant of other maps? How do I go about adjusting to make them either equal, or at least parallel so they scale equally?
Thanks
Old May 24, 2010 | 03:25 PM
macr88's Avatar
Is this what you're talking about?
Old May 24, 2010 | 03:30 PM
whiteflash's Avatar
Huh? I don't see a pic or link or anything mac
Old May 24, 2010 | 03:35 PM
macr88's Avatar
I guess a link might help now I have to find it again
Old May 24, 2010 | 03:36 PM
macr88's Avatar
https://www.s2ki.com/forums/index.ph...f=231&t=774218
Old May 24, 2010 | 03:42 PM
whiteflash's Avatar
Yea I have updated, but then again maybe the datalog I'm looking at was pre-update. If that's the case, then I'm going to feel really stupid LOL
Old May 25, 2010 | 07:24 AM
Gernby's Avatar
Former Sponsor
Is this just an OCD kind of thing about the values not matching up on the datalogs, or do you actually want to change the behavior of your throttle? If it's the latter, then I suggest that you take a look at the "Target Throttle Plate" map that is under the "Throttle" category in the Calibration. The default map is a 1:1 ratio of pedal position to throttle plate, but it doesn't actually work out quite that way as you've noticed.
However, there are reasons why you might want to alter the mapping in order to change the way the car drives. For example, if you want to make the pedal more or less sensitive, you can tune it to your liking. You can make the throttle curve logrithmic for a more sporty / responsive feel, or you could give it an exponential curve to make it feel a bit more numb at part throttle. You could also limit the max throtlte opening so that your teenage brother or valet can't abuse it.
I recently altered this table so that I could create 3 "zones" of throttle levels to aid with part throttle tuning. It worked VERY well for tuning, but was a bit awkward to drive.
Gernby
Jul 21, 2016 05:59 AM
dj_ap1
Aug 5, 2014 06:15 AM
c32b
Dec 6, 2011 11:53 PM
ace123
Mar 18, 2010 08:29 AM
Gernby
Jan 11, 2010 10:14 AM
