Ordered E manage
Old Jun 16, 2010 | 05:27 PM
thdrew's Avatar
Default Ordered E manage
Just bought and emanage ultimate, is there anything else i need? o2 sensor, or anyting small to make it work better?
Old Jun 17, 2010 | 09:17 PM
jb34304's Avatar
If you are forced induction I would recommend getting a 3 bar MAP sensor. Anything over 10 psi and the stock sensor won't work. The nice thing with a piggy back is it uses your stock sensors. That is about all the pros of it tho.
Old Jun 21, 2010 | 01:40 PM
s57_s2k's Avatar
this wire is used to connect the O2 sensor controller to emanage
Old Jun 21, 2010 | 09:57 PM
iheart9krev's Avatar
You'll need wiring harness (boomslang) if you aint got it already. What are your plans for it? NA or FI? Do u plan to learn to tune yourself or going to take it to a tuner? If taking to tuner, you dont need anything else but harness. You can get parts that will maximize your tune, like TP or bored TB.
If you going to tune yourself, get o2 sensor and cable above so it can read the wideband. Search Emanage 101 to get started on install and adjusting maps.
jaundice
Feb 23, 2010 08:30 AM
UsmcSway
Oct 22, 2008 05:23 PM
syellow
Nov 14, 2007 01:11 PM
ChefJ
Mar 24, 2007 09:04 AM
NightStalker
Dec 31, 2005 01:19 PM
