A little help with emanage PLEASE
Old Nov 14, 2007 | 12:29 AM
syellow's Avatar
Default A little help with emanage PLEASE
Ordered the emanage and harness so I don't have to splice into my wires. There is a boost connector (3 pin) I'm running a garret t3 60-1. Can anyone tell me which sensor I have to buy to plug in there? There are multiple ones available. Please Please help me. I think it might be some pressure sensor. Thanks
Old Nov 14, 2007 | 05:16 AM
CIVICTOS2000's Avatar
thats right you can use the pressure sensor or if you have a wideband with 0-5v output you can also use it as a WB input using the same harnes from the pressure sensor you can get more info here Emanage Info
D.
Old Nov 14, 2007 | 07:56 AM
syellow's Avatar
That was helpful thank you. I'm about to purchase the pressure sensor and harness now. Where does the actual sensor hook up to? Does it take the place of a factory sensor, or somewhere else? Thanks again
Old Nov 14, 2007 | 01:11 PM
a good vaccum source..
ScienceofSpeed
Jan 24, 2011 01:17 PM
thdrew
Jun 21, 2010 09:57 PM
jaundice
Feb 23, 2010 08:30 AM
ChefJ
Mar 24, 2007 09:04 AM
NightStalker
Dec 31, 2005 01:19 PM
