Please Help with Idle in Haltech
Old Apr 9, 2013 | 08:44 AM
tx2K's Avatar
Default Please Help with Idle in Haltech
Guys, I had some trouble with low/unstable idle right after I got my car back from the tuner, but I fixed those issues by increasing the base duty. However, this only fixed the problem with the A/C off. When I turn the A/C on, the added load makes the car start idling up and down again from like 800-1300 ish. I adjusted the A/C offset table a little bit, but it didn't change much. Should I just keep increasing the offset percentage until it finally smooths out or what? Any help is appreciated!
Old Apr 17, 2013 | 12:38 PM
titoracingfab's Avatar
Email me ill send you my setup but first try to adjust timing it helps
Old May 5, 2013 | 01:01 AM
ConeKiller2's Avatar
You likely have a bad IAC. Try cleaning replacing that first
Sent from my SGH-I747 using Tapatalk 2
S2SEXY
Aug 30, 2008 08:12 AM
THE_DIESEL
Apr 11, 2007 08:56 PM
S2K TX
May 10, 2005 07:54 AM
JMP9982
Nov 27, 2002 09:44 AM
