Crankshaft sensor and AEM EMS
Old Feb 12, 2019 | 03:28 PM
chtmatthew's Avatar
Default Crankshaft sensor and AEM EMS
So I installed my scienceofspeed supercharger, took my timing chain cover off to have a drain bung welded, installed the AEM EMS and had my tuner come install a base map, however he wasn’t getting a crankshaft signal, car started right up on the stock ECU however, then we tried another AEM EMS, exactly like mine.. same thing no signal.. here’s a list that will be easier to understand if my troubleshooting steps:
No signal from crankshaft sensor to AEM EMS, doesn’t start on AEM because of this, tuner says.
Stock ECU starts it right up with sensor plugged in, no CEL, idles fine but boggy (no tune).
When sensor is unplugged on stock ECU, starts but dies quick, shows CEL for bad sensor
Sensor shows resistance around 2,100 ohms (manual says between 1,850-2,450 is good)
When cranking, sensor shows AC voltage at about 0.3 (online states between 0.3 and 5 is normal)
When car starts, sensor shows AC voltage at 1.5 volts, when starting it was a bit more but at idle it’s about 1.5
Check all wiring, no shorts, everything reaches the cabin.
Old Feb 12, 2019 | 07:13 PM
afzan's Avatar
Are you sure they used the correct base map? AEM provides base maps, try that
also which specific AEM EMS do you have
Old Feb 13, 2019 | 01:44 AM
chtmatthew's Avatar
AEM V2, yes correct base map, tuner knows what he’s doing, even tried his AEM V2 out of his running AP1, i’ve got the AP2 aswell.
Old Feb 13, 2019 | 01:46 AM
chtmatthew's Avatar
I meant to say i’ve got the AP1 aswell
Old Feb 13, 2019 | 02:06 AM
flanders's Avatar
Well seems pretty clear the problem is in the AEM EMS, maybe it's just more sensitive than the OEM ecu.
Are you getting the measurements right at the ecu connector?
Have you tried to take a look at the signal with a scope?
Old Feb 13, 2019 | 03:38 AM
chtmatthew's Avatar
Haven’t tried a scope, was using a regular multimeter. Yes I checked right at the connectors by the ECU. It might be something with the AEM but we tried his AEM aswell.. I might just throw another sensor in there and see what happens because I’m just lost at this point. I email AEM last night but my tuner had a call with them yesterday and they weren’t much help anyway.
Old Feb 13, 2019 | 04:50 AM
flanders's Avatar
A scope could tell a lot more on what's happening so if you can get one hooked up that might really help.
You could also try and check the trigger wheel teeth for any damage, if you remove the sensor and peek inside the hole while you hand turn the crank.
Old Feb 13, 2019 | 05:58 AM
chtmatthew's Avatar
I’ll try to get in there today and have a look, It’s a real pain with the SC on there.
blink962
Oct 10, 2016 08:04 AM
thanasis11
Nov 9, 2013 05:20 PM
Spec_Ops2087
Oct 29, 2007 06:38 PM
Stoner_1
Sep 5, 2006 02:00 PM
stevharr
Aug 29, 2006 07:36 PM
