Quick V2 EMS and MAP Sensor
So i searched around and couldnt find anything. But my tuner couldnt find what the transfer function is on a SOS 3 Bar MAP Sensor. Does anyone know off hand what the transfer function is on this sensor and if not is it the same as any other 3 bar stock location sensor. I am just trying to have a base map for my ptuning/3076R/ID1000/Stock Catback 11psi sent to me today and he cant do that unless i can find out what the transfer function on the sensor is.
Anyone have a map they want to send me??? P Tuning 3076, ID1000, Walbro 255, Stock or 3 bar Sensor...
great thank you. quick question... I purchased this sensor used. When my car was stock i was under the asumption that i could replace my stock map sensor with this sos 3 bar and it would make no difference. But when i put it in the car... and even now do with the turbo and aem ems the car would barely idle and then die. Is this because the ecu has not been calibrated to these parameters and it would not run... or is it likely a bad sensor?? Just need to know if i should try and get tuned with this one, stay under 10.8 psi and stay with the stock for now, or purchase a new 3 or 3.5 bar map sensor?
thank you
thank you
