AEM 3 bar map sensor
Old Apr 8, 2012 | 09:28 PM
specialist's Avatar
Default AEM 3 bar map sensor
I have a AEM 3 bar map sensor. Any one know how to wire it in to ap1 wire harness? I cut the stock map sensor now i have 3 wires that need to plug and wired in? Any one have the wire diagram?
Old Apr 8, 2012 | 10:58 PM
AusS2000's Avatar
Search is your friend. I seem to remember a very helpful thread by on 'AusS2000' several years back.
Old Apr 9, 2012 | 07:18 AM
s2knoob89's Avatar
SOS 3 bar FTW!
Old Apr 15, 2012 | 07:51 PM
specialist's Avatar
This is what i found no help lol
The aem sensor does not come pre wired. Still no luck any help????
Well we all know that when going forced induction and boosting above ~10psi the stock MAP sensor starts to go wack. I decided to use an AEM 3.5 bar MAP sensor. This is a rather easy install, but with no instructions included with the MAP sensor, it could be confusing.
Mounting it I decided to use this block adaptor from Tuner Toys:
http://tunertoys.zoovy.com/c=uogsUib...vic_Turbo.html
It screws right in to the factory MAP sensor spot. $20 well spent.
You can mount it anywhere, the block was personal preference.
Once mounted, cut off the factory MAP sensor clip.
Cut down the AEM (or whatever other brand sensor you used) MAP sensor wires. Shear the ends and start soldiering.
Red goes to yellow/red
Green goes to green/red
Black goes to green/white
Be sure to use some shrink wrap to protect the connections.
If you are using the AEM EMS, be sure to use the map sensor wizard and choose the map sensor you are using.
Old Apr 15, 2012 | 09:04 PM
AusS2000's Avatar
Did your MAP sensor come like this?
If so, just wire up as per the directions in your quote.
https://www.s2ki.com/s2000/topic/437...m+map+auss2000
Old Apr 16, 2012 | 09:18 AM
05TurboS2k's Avatar
Originally Posted by s2knoob89
SOS 3 bar FTW!
I concur. Glad you pointed me to that. So nice just dropping it into the stock spot.
Old Apr 17, 2012 | 09:24 AM
specialist's Avatar
you have to pin it out your self it doesn't come pre pinned so you can make any wire any colour
F1TwoThousand
Oct 15, 2018 08:54 AM
kosdali
Κινητήρας - Μετάδοση - Περιφερειακά
Dec 11, 2014 03:10 AM
EriS2k
Apr 22, 2008 05:43 PM
waytooslow
Apr 24, 2006 08:04 PM
Silver S2k4
Aug 27, 2005 02:02 PM
