Replacement ECU connectors
Old Jun 1, 2010 | 08:31 AM
Irishflame27's Avatar
Default Replacement ECU connectors
One of my ECU connectors is damaged, and wont stay clipped into the ECU, does anyone know where i can get a replacement, are these connectors the same as any other OBD2 honda?
Old Jun 1, 2010 | 10:06 AM
DFWs2k's Avatar
pretty sure they are all the same, since you can just order them from summitracing.com, they are 1.99 each on that site
Old Jun 4, 2010 | 06:34 AM
maluch's Avatar
aem sells them for $67
http://www.aemelectronics.com/plug-n-pin-k...50s-1052s-s-780
if someone knows where you can find something cheaper please let me know.
I tried finding them on summit racing but was unable to do so. DFWs2k can you point us with a link?
Mouser electronics also sells Delphi connectors so maybe they can be found there...probably not however...
Old Jun 4, 2010 | 07:13 AM
DFWs2k's Avatar
this is what i was pointed to:
http://www.summitracing.com/parts/AVM-3-1000-S/
Old Jun 4, 2010 | 07:35 AM
wadzii's Avatar
Banned
the connectors are the same 96-00 civic and 96-01 integra
the aem plugs are not a bad deal, they come with all the pins as well. useless for replacing a plug but good when you are building a harness
Old Jun 4, 2010 | 08:20 AM
joes sled 2000's Avatar
Go to a junk yard . Quick and easy .
Old Jun 4, 2010 | 08:24 AM
maluch's Avatar
connector extraction is a PITA so your best bet is getting the pin from summit and just replacing it.
Old Jun 11, 2010 | 07:42 AM
i got one local from hasport, same as all obd2 hondas
s2konroids
Aug 31, 2009 11:31 PM
Dave.B
Jul 30, 2008 01:40 AM
REV_29K
Mar 1, 2005 10:12 PM
AustinS2k2003
May 14, 2004 07:08 PM
