Running Lean, Rough Idle
Old Aug 26, 2012 | 08:13 AM
f22cjh4's Avatar
Default Running Lean, Rough Idle
So recenly, about a month ago, I got a turbo system installed on my S and was tunned by Jeff at Evans Tuning. Its an AP2 and I'm running K-Pro. Well about a week ago the car started to idle real rough and it almost sound like there was tapping coming from the engine bay, ALSO when acclerating the car spudders.. This only happens when the car and the oil is fully warmed up. ANy Ideas of what the problem could be. I definately know the car is running lean, but why is this happening all of sudden out of no where and only weeks since my last tune
Old Aug 31, 2012 | 10:06 AM
Gernby's Avatar
Former Sponsor
Contact Jeff about it...
Old Sep 5, 2012 | 01:03 AM
silvermonster's Avatar
update?
Old Oct 2, 2012 | 01:47 PM
f22cjh4's Avatar
Found out what the issue was.. A fouled spark plug in cylinder 1. Everything else came out fine compression good in all 4 cylinders
Old Oct 2, 2012 | 07:30 PM
s2000Junky's Avatar
Did you determine how your one plug fouled? Thats a rather strange situation on a well tuned car out of no where. Typically this happens from a bad coil, running extremely rich and or oil contamination from a mechanical failure of sorts. Something happened...
Gators2kt
Jul 14, 2013 10:42 AM
modMonkey
Jul 9, 2013 02:00 AM
helloimsteve
Feb 6, 2013 04:10 AM
batikan
Jun 15, 2007 08:58 AM
BrandonJay_1983
May 4, 2007 08:46 AM
