ScienceofSpeed AEM Infinity Based Engine Management & Traction Control
Old May 12, 2020 | 09:01 AM
ScienceofSpeed's Avatar
Former Sponsor
Originally Posted by pastoli
F1TwoThousand I have it on my 2003 race car. I need to find out a good MPH setting for it.
Drop us a line if you need instructions!
Old May 12, 2020 | 04:30 PM
treimche's Avatar
Originally Posted by ScienceofSpeed
Please drop us an e-mail to info@ScienceofSpeed.com - we recently updated the instructions, and it includes how to configure a multi-position switch to vary traction control thresholds based on switch position.
Thank you. Your customer service is the best there is!
Old Jul 29, 2020 | 03:49 PM
mys2k3's Avatar
Originally Posted by treimche
I have this on my 2005 S2000 and it works great. I haven't messed with any of the settings other than turning the traction control on or off though. Also recently got the AEM 12 position trim switch from SOS but there were no instructions on how to wire it in or set it up in the Infinity, so it might be a while before that is set up.
How did you wire yours in? I’m currently trying to figure this out as the infinity doesn’t have a lot of extra inputs and I want to be able to adjust boost and traction through my BTI dash.
Old Jul 30, 2020 | 04:51 AM
treimche's Avatar
I wired in the SOS speed pulse converter and set it up according to their instructions that they send with it. For the AEM 12 position trim knobs, I still haven't taken the time to get these installed. It looks like all you need for each knob is +5v, ground, and a signal wire to an input at the Infinity, but then you have to figure out the settings, which is where I'm really unsure. The only instructions SOS has sent for the trim knobs is this: https://www.aemelectronics.com/files...Trim%20Pot.pdf
Old Aug 2, 2020 | 07:43 PM
Charper732's Avatar
Wiring is:
1 Red (Supply Voltage 5Vdc +/- .5), 1 Black (Ground), 1 White (Output)
When you go into infinity tuner, go to "wizard" and then "input function assignments" From there under analog input 0-5 tab you will see "modeswitch input setup" and "Traction control sliptarget trim" There are your two options for the trim pot switches. If you are using one for boost and traction control, the you would use both. From there click on either one. For mode switch you will select "modeswitch" as the input and for the traction control you will need to select an analog input. From there you just need to wire it to whichever analog pin you selected.
You can get fancy with it and wire it into the stock cable reel. There is a spare unused pin that would allow for enough pins to use two trim pots. If you use two cruise control housings you can put boost and traction control on the wheel
browncow
Cars for Sale
May 19, 2018 12:37 PM
GUTI007
May 1, 2017 05:59 PM
bigeazyxx
Mar 7, 2017 10:51 AM
foertmeyer
Cars for Sale
Feb 7, 2017 05:18 PM
Redsox01
NYC Metro Stock Exchange
Aug 19, 2016 10:03 AM
