Setting base timing
Old Oct 1, 2010 | 09:53 PM
jb34304's Avatar
Default Setting base timing
I know this is a really dumb question, but I couldn't find the answer anywhere. I am tuning my car and need to set the base timing. What should it be @ 1k rpm's? Don't flame me for this question either, but I am supposed to connect the light to the #1 (Coil wire on the front cylinder)?
Old Oct 2, 2010 | 12:08 AM
whiteflash's Avatar
I can't give you the exact answer but for those who can...
At what throttle %? And low cam or high cam?
Old Oct 2, 2010 | 10:32 AM
jb34304's Avatar
I was going to set the timing at idle first. Using aem it is under configure>ecu>set ignition. Pretty sure it is set @ 4 degrees adv. I heard most cars are set around 10. Couldn't find anything for this car. Would it be in the service manual?
Old Oct 3, 2010 | 04:35 AM
whiteflash's Avatar
Ah, I can check my flashpro on Monday... I've never touched idle settings.
Old Oct 3, 2010 | 12:44 PM
Dan1987's Avatar
the ign values for idle are closed loop I believe as the ignition timing varies to control idle.
Here are the stock equivilent maps for the F20c.
Low cam:
High cam:
I should of made them a little larger. but i think you can just make make them out.
Old Oct 5, 2010 | 10:00 AM
jb34304's Avatar
Low cam:
High cam:
The pictures are fine. I can read the numbers easily. I will compare your map to mine when I get off work. Are you FI or n/a? how much boost are you running? My origional question was: In the aempro there is a setting in the drop down menu to set base ignition. I was going to hook up a timing light and set it correctly, so I can get a proper tune. I appreciate you posting the maps. It is nice to be able to compare to another s2k to see if I am tuning too agressive, or if I have room to improve. And my o2 sensor is probably toast right now so I will have to wait a couple days for a new one .
Old Oct 5, 2010 | 12:10 PM
Dan1987's Avatar
Ah ok..im FI (supercharged 11psi), that map i pictured above is for a bog standard NA s2000. my ignition timing goes down to 21 degree's of advance at about 9000rpm. so about 5-6 degree's more retard than NA.
Old Oct 5, 2010 | 04:06 PM
jb34304's Avatar
I am turbo'd @7 right now.
Old Oct 6, 2010 | 05:11 AM
scareyourpassenger's Avatar
That doesn't include the ignition retard from the knock control..
Old Oct 18, 2010 | 09:45 AM
maluch's Avatar
can someone post the stock f22 values? thanks
