Should I be worried
Old Apr 26, 2020 | 10:08 PM
Scotts2knyc's Avatar
Default Should I be worried
Just bought my s2k a few weeks ago , got a ‘04 with 158k miles on it. I’ve already done some regular stuff on it ( new tct , new clutch master cylinder , valve cover gasket , spark plugs , oil change , oil filter and then some other little o rings and gasket changes ) Wanted to get some opinions on other things I should do to make the car last as long as I can. This car won’t be tracked at all and will just be for casual daily driving to school
Old Apr 27, 2020 | 04:12 AM
EOE's Avatar
EOE
Valve adjustments
Old Apr 27, 2020 | 06:15 AM
Originally Posted by EOE
Valve adjustments
got an appointment with billman for that May 6th (:
Old Apr 27, 2020 | 07:55 AM
Bullwings's Avatar
all of the other fluids - brake, transmission, differential. Look in the engine bay for brittle/cracking plastic - notably, the coolant overflow tank. Other than that, drive, enjoy, and have fun.
Your shifter might be a little bit sloppy - there are a number of plastic pieces in there that are wear and tear items for a 16 year old car.
Old May 4, 2020 | 09:48 PM
windhund116's Avatar
Tell us, how it went. Thanks!
Old May 4, 2020 | 09:55 PM
Two more days until I go see him , hopefully all I need is the valve adjustment. Just put bc coils on and installing front lower control arms and whiteline adjustable end links all around ( 3 out of my 4 end links on right now are snapped) and also widebodying it Wednesday!
Old May 5, 2020 | 05:28 AM
Chuck S's Avatar
Why bugger it with a "wide body kit?"
-- Chuck
Old May 5, 2020 | 05:38 AM
Got a really good deal on one from one of my buddies
TangoVTEC
Jun 5, 2019 04:24 AM
Delta_lima
Mar 14, 2019 07:06 AM
jackmugen02
Feb 25, 2019 07:28 PM
Spaceentity
Feb 5, 2018 03:05 PM
ralper
Sep 19, 2016 05:17 PM
