Software Dyno for FlashPro users (and maybe KPro)
Old Aug 11, 2015 | 12:09 PM
  #151
steelers743's Avatar
Does this still work? I tried to it on a new datalog and it didn't work but it could be me. I haven't used flashpro in forever.
Old Aug 19, 2015 | 12:48 PM
  #152
imstimpy's Avatar
Did you make the modifications to the macro as I detailed in the thread?
Old Aug 20, 2015 | 11:23 AM
  #153
imstimpy's Avatar
Now that I look at back, this worked in FlashPro v1.5.9-1.6.3. It initially broke because they injected PTANK and ECT2 into the middle of the data and caused the columns to shift. Since that time they've added the CRZ, Fit, and Accord moving up to 2.3.0. Given their track record, it is conceivable that they have further shifted the columns.
I opted to stick with an older version since that is what worked on the S2000. Their notes never indicated updates to the core software. Newer adopters don't have the option to use the older versions...
If you want to provide me with a log file from the latest version of FlashPro, I can tell you how to edit the Excel file or re-host it myself. If you don't or can't get me a log file I will (eventually) update FlashPro and be forced to make the modifications for my own needs.
Old Aug 21, 2015 | 06:18 AM
  #154
I just saw the script, Ill go ahead and give it a try. I sent you a PM not sure if I can upload to here without being a member.
Old Aug 22, 2015 | 09:22 AM
  #155
imstimpy's Avatar
You can download Gernby's original (compatible with FlashPro 1.5.9), my preivously updated (compatible with 1.6.3), and the latest (compatible with 2.3.0) here:
https://www.dropbox.com/sh/c6umjyftf...42Kg_zGWa?dl=0
For those interested, here are the FlashPro Log Formats compatible with Public Soft Dyno Updated 2.3.0.xls
FlashPro 2.3.0 Log Format
Code:
Export of E:\Steelers\Documents\FlashPro Calibrations\pull1.csv
Number of frames 1697
Length: 0:00:08.725s
frame,time,RPM,VSS,Gear,PTANK,MAP,TPedal,TPlate,AFM.v,AFM,AFM.c,INJ,INJ Bank 2,DUTY,IGN,IAT,ECT,ECT2,CAM,CAMCMD,AF,AF Bank 2,AF.Corr,Wide.V,Wide,S.TRIM,L.TRIM,S.TRIM Bank 2,L.TRIM Bank 2,Fuel Status,Fuel Status Bank 2,K.Level,K.Retard,K.Control,Ign.Limit,K.Count,K.Count.1,K.Count.2,K.Count.3,K.Count.4,K.Count.5,K.Count.6,PA,BAT,VTS,SVS,Purge,Eco,Fuel Used,BC Duty,TC.V,TC.ECUSlip,TC.R,TC.LF,TC.RF,TC.LR,TC.RR,TC.Slip,TC.Turn,TC.OverSlip,TC.Out
0,0,2979,29,3,0.0,-0.2,100,101,0.00,0.00,0,10.66,0.00,26,18,127.4,194.0,32.0,0,0,10.95,0.00,12.73,0.00,10.00,0,-1,0,0,4,0,32,0,55,24,1,0,0,1,0,0,0,0.0,12.40,Off,Off,0,0.0,0.000,0,0.00,0,0,0,0,0,0,0,0,0,0.00
FlashPro 1.6.3 Log Format
Code:
Export of G:\FlashPro Calibrations\PWJDM install\PWJDM install J WOT 29%.csv
Number of frames 666
Length: 0:01:04.203s
frame,time,RPM,VSS,Gear,PTANK,MAP,TPedal,TPlate,AFM.v,AFM,AFM.c,INJ,DUTY,IGN,IAT,ECT,ECT2,CAM,CAMCMD,AF,AF.Corr,Wide.V,Wide,S.TRIM,L.TRIM,FuelStatus,K.Level,K.Retard,K.Control,Ign.Limit,K.Count,K.Count.1,K.Count.2,K.Count.3,K.Count.4,K.Count.5,K.Count.6,PA,BAT,VTS,SVS,Purge,BCDuty,TC.V,TC.ECUSlip,TC.R,TC.LF,TC.RF,TC.LR,TC.RR,TC.Slip,TC.Turn,TC.OverSlip,TC.Out
0,0,1695,16,3,0.0,252,10,5,0.00,0.00,0,2.34,3,22,120.2,190.4,32.0,0,0,29.40,29.40,0.00,10.00,0,0,1,15,0,55,18,0,0,0,0,0,0,0,0.0,13.70,Off,Off,0,0,0.00,0,0,0,0,0,0,0,0,0,0.00
FlashPro 1.5.9 Log Format
Code:
Export of G:\FlashPro Calibrations\PWJDM install\PWJDM install B WOT 55%.csv,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Number of frames 600,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Length: 0:01:08.031s,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
frame,time,RPM,VSS,Gear,MAP,TPedal,TPlate,AFM.v,AFM,AFM.c,INJ,DUTY,IGN,IAT,ECT,ECT2,CAM,CAMCMD,AF,AF.Corr,Wide.V,Wide,S.TRIM,L.TRIM,FuelStatus,K.Level,K.Retard,K.Control,Ign.Limit,K.Count,K.Count.1,K.Count.2,K.Count.3,K.Count.4,K.Count.5,K.Count.6,PA,BAT,VTS,SVS,Purge,BCDuty,TC.V,TC.ECUSlip,TC.R,TC.LF,TC.RF,TC.LR,TC.RR,TC.Slip,TC.Turn,TC.OverSlip,TC.Out
0,0,1893,18,3,162,0,2,0,0,0,0,0,18,109.4,183.2,32,0,0,29.4,29.4,0,10,0,-4,4,10,0,55,27,0,0,0,0,0,0,0,0,14,Off,Off,0,0,0,0,0,0,0,0,0,0,0,0,0
Jeremy Clarkson
Jun 6, 2013 05:10 PM
s57_s2k
May 18, 2011 08:07 PM
Spec_Ops2087
Mar 26, 2007 09:13 PM
1036AP2
Jun 19, 2006 04:07 PM
Venomous S
Jun 18, 2006 07:26 AM
