Stock rev limiter
Originally Posted by spectacle' timestamp='1306810064' post='20632333
[quote name='gernby' timestamp='1289237676' post='19782880']
You would not want to cut ignition instead of fuel, since that may fuel wash your cylinders, contaminate your oil, damage your catalytic converter, and create a lot of soot on your back bumper.
Yes back from the dead.
[/quote]
Its not about unignited fuel, its about retarding timing. Pulling timing increases EGT's which helps the turbo spin faster than normal, spooling it at launch or between shifts. The extra fuel is to keep everything from getting TOO hot to blow things up
That's interesting, but I don't see how it's on topic with the rev limiter. The stock rev limiter doesn't retard timing. It shuts fuel off completely.
And you said
Making the point that a rev limiter that pulls timing is useful in many instances, just not for N/A cars.
And for the record, you'd have to dump MASSIVE amounts of fuel in a motor to fuel wash it. We're talking in the 7's and 8's AF. The chances of that happening are highly unlikely.
And I'd still like an answer to this...
dan_uk
63
Jan 11, 2012 12:18 AM
