swapping an MY05 engine into a MY00
Old Feb 15, 2012 | 04:41 PM
pd0019's Avatar
Default swapping an MY05 engine into a MY00
So I have a blown engine. Pitted pistons and scratched cylinder walls. I found a 2005 engine and was wondering if I can do a direct swap without needing to switch out the ECU, ignition switch, ignition, reprogramming the key, and whatever else might need to be done (wiring harness?). I assume this would involve just leaving the intake manifold/intake and header/exhaust and just swapping the long block.
I am going to be doing this with a friend in the next couple weeks if I can do the swap, so any pointers would be helpful as well
Old Feb 17, 2012 | 10:13 PM
pd0019's Avatar
any help?
im just hoping there are no other sensors on an 05 engine and if using a MY00 ecu will hurt the MY05 engine?
Old Feb 18, 2012 | 12:56 PM
JUSTINTHECOASTIE's Avatar
Not trying to be a dick, but did you search...any? Many of us have done this swap already and have threads about them. Read up on them. To answer your questions, when doing the swap use the ap1 fuel rail, wire harness and ecu.
Old Feb 26, 2012 | 01:01 PM
TheCarGuy2021's Avatar
I dropped in a '05 engine in my '00 two years ago when my '00 engine was starved of oil. No modifications needed (used the '05 harness and fuel rail), stock '00 ECU should be fine although I'm using AEM V2. PM me if you have any specific questions.
Old Feb 28, 2012 | 11:00 AM
BoostNhigh's Avatar
I did the same swap. These are the only different pieces you will come across.
BE careful NOT to break the knock sensor
Old Feb 28, 2012 | 12:16 PM
I totally forgot about the knock sensor LOL when installing remove it before place the engine in the bay, reinstall it when you place the engine on the motor mounts, I broke 2 of them, one was my fault, the other my helpers fault LOL they are fragile
Old Feb 28, 2012 | 12:26 PM
pd0019's Avatar
Thanks guys for the replies and sorry for not searching first. I generally always do that first, but it skipped my mind this time.
I'm actually going to sell my car. Have a couple interested people
blipboss
May 22, 2017 04:41 AM
f20cmx5
Sep 27, 2012 02:48 PM
Xherrox
Nov 15, 2008 10:58 PM
crank
Sep 11, 2008 03:48 PM
ack5252
Mar 23, 2008 02:01 PM
