Tuning for my New Setup
Old May 2, 2011 | 11:30 AM
ViperASR's Avatar
Originally Posted by s57_s2k
Originally Posted by ViperASR' timestamp='1301325723' post='20403223
Just FYI, I have a similar setup, and I picked up ~20 peak WHP over the TODA tune when I got mine dyno tuned.
The midrange HP and Torque pickups were amazing.
My VTEC engagement is also higher than the TODA tune due to the lack of a testpipe. I think mine is actually higher than a lot of people here, but it showed no improvement on the dyno by lowering it. We did 13+ full runs on the dyno, with a bunch of lower end runs working on VTEC and mid-range.
from where did most of that power came (AFR or timing ) ?
Both?
He made changes to both Fuel and Timing maps, so I'm not sure where most of the power came from.
Old May 2, 2011 | 02:42 PM
steelers743's Avatar
@SwiftGT post up ur datalogs here of daily driving and also a 3rd gear WOT pull and we can look at them more and see if the AFR are good
Old May 2, 2011 | 04:17 PM
Swift GT's Avatar
Here it is:
[attachment=1710:IMG_1677.JPG]
Old May 2, 2011 | 11:39 PM
I can't tell what the lower number is bit the a/f could use some work you want it to be flat and lvl around 12.8...on that note it doesn't look like any of the a/f could be super dangerious that's going to blow the motor
Old May 3, 2011 | 05:32 AM
s57_s2k's Avatar
use external wideband for AFR because AF in the flashpro read richer . or you could use AF corr if you dont have time for a wideband . my wideband reading is very close to AF corr reading .
Old May 3, 2011 | 08:19 AM
b.r.i.a.n.'s Avatar
instead of taking a screen shot, post the actual log. to save the datalog hit datalog and save as. give it a name and upload it as an attachment to your reply on the message board.
Old May 3, 2011 | 09:12 AM
silvermonster's Avatar
thats strange. There must be some kind of confusion.
Didn't gernby install a wideband on his car and determine that the AF reading is closer to AF instead of the AF Corr?
AF actually read a tad richer than the WB sensor.
I know on my car, the AF corr and the AF are totally different. AF corr reading much higher than AF.
Old May 3, 2011 | 02:47 PM
I havnt tried an aftermarket wideband yet but if I correct for 12.8 on the a/f corrected number my fuel tables look way outs wack and the WOT tables looked way rich abover everything else.....a/f looks alot better
Old May 3, 2011 | 08:56 PM
Swift GT's Avatar
I'm going to be starting an Evans E-Tune any day now anyway, so my current datalogs are relatively irrelevant
Old May 4, 2011 | 05:52 AM
acus2k's Avatar
Hmm. I hope my setup is safe, i am also on the TODA tune, intake, berk header, and t1r 70mm tp and exhaust...
