tuning out knock? please help
Old Nov 27, 2009 | 03:12 PM
Hondata's Avatar
Former Sponsor
Originally Posted by EliteTuning,Nov 27 2009, 10:26 AM
Originally Posted by dstevens
Ignore the knock retard and knock %. The only thing to look at is the knock count.
https://www.s2ki.com/forums/index.php?showtopic=745922
wrong! Contact me and I can tune it without being there for under $70
Mike, why shoot down anyone who offers tuning advice in the interests of your own, rather shameless, self promotion? Do you realize I post under both Hondata and dstevens?
Old Nov 27, 2009 | 06:51 PM
EliteTuning's Avatar
that was not my intentions and i apologize if i came off that way. I've thus edited my post. Thank you for catching what I wrote & I Didn't know you were Dstevens! Now for my questions
What is the reason to only look at knock count? Knock count increases based on noise the knock sensor picks up. So it could be ghost knock, right?
Old Nov 27, 2009 | 06:58 PM
Originally Posted by 93turbo16,Nov 27 2009, 12:04 PM
Ok. So let me get this straight.
Even if you get phantom knock you don't turn the knock sensor off?
So by leaving the knock sensor on you are letting the ecu retard timing even though there are not any "real" knock counts?
Because in both K-manager and Flash Pro there is not a user accessible knock filtering table to filter out any un-wanted knock counts.
I promise you the easiest solution is to disable the knock sensor and tune the ignition timing accordingly. It is a far better way of trying to tune around phantom knock, without having a knock filtering table to adjust what you want to keep out.
you can adjust knock sensitiivity with flashpro! One of the things k-pro should have
Old Nov 27, 2009 | 07:28 PM
93turbo16's Avatar
I just checked that out, I missed it the first time. Definitely a great thing to add in there when working with a stock motor S2000.
You want to worry about knock count instead of knock retard because if you read the post linked above, when the ecu sees knock at say 4000 RPM, it will apply a knock retard the whole way through the RPM range, not just at the point where the knock was recorded. It will do this even if the knock sensor is no longer picking up anything.
So essentially you want to limit knock count throughout the RPM range, and in return you will have a lesser knock retard.
Old Nov 27, 2009 | 07:33 PM
Originally Posted by 93turbo16,Nov 27 2009, 08:28 PM
I just checked that out. I missed it the first time. Definitely a great thing to add in there when working with a stock motor S2000.
thanks for the clarifications. I guess the knock sensor is engineered a different way compared to a k20 knock sensor. That's where I was wrong and I admit my wrongness. My apologies to Hondata (derek and doug) and to the s2k community.
Less knock count and retard, the better! Right?
Old Nov 27, 2009 | 07:41 PM
93turbo16's Avatar
Exactly.
What I mentioned above is definitely a simplification of how the knock control system works as a whole, but should be easy enough for most to understand when starting out.
Hondata's post up above has some good info in it.
Old Nov 28, 2009 | 03:56 PM
Hondata's method about removing knock and helping the rest of the powerband didn't hold true on my clients car today on the dyno. Maybe it does on others, but it didn't on this car. Lost power when adding timing and didn't lose when removing 2 degrees from the knock areas.
I'm not saying they are right or wrong. I was just stating that it didn't hold true on this particular motor.
Old Nov 29, 2009 | 05:29 AM
08s2000CRbackinblack's Avatar
whats the most ignition degrees most are using around 7-8k? my map has around 26
Old Nov 29, 2009 | 08:39 AM
93turbo16's Avatar
I am not sure what you are getting at with this. Did you mean didn't gain when removing 2 degrees from the knock areas?
Did the knock go away when you removed timing from the car? How many counts were you seeing? What was the knock retard level through out the powerband?
I am not really surprised that it lost power when you added timing to it.
Old Nov 29, 2009 | 09:09 AM
i really appreciate the help with the knock, my tune is looking clean no knock and keeping my WOT a/f around 12.5-12.7 this sounds good to me but im very new to tuning. the reason why i mentioned the question above is because i was wondering if there is anymore power i could eek out with ignition timing. i wouldnt mess with the timing myself but my tuner said he could mess with it but if theres not much to play with i was thinking of keeping the tune like it is for a few months until i boost. please any advice would be wonderful
