tuning out knock? please help
Old Dec 2, 2009 | 06:58 PM
  #31
EliteTuning's Avatar
this shows how good the s2k is tuned, as far as ignition timing is concerned, from factory
Old Dec 3, 2009 | 11:25 AM
  #32
JustinC's Avatar
Originally Posted by thesilverbullet,Dec 1 2009, 07:38 PM
hondata has discussed this in a thread about how the ecu always has a certain amount of retard.
i loved my rsx's kpro - it has an option to flash the cel light with every knock count... and i could adjust timing by gear
backinblack, what's your mods? hondata didn't find any gains with timing with their n/a test mule on 91 pump. if you are still n/a with typical bolt-ons you should have an a/f target of low to mid 13s. also to see the knock count do a 3rd or 4th gear WOT pull and add kcount to the graph. you can graph the total kcount and kcount by cylinder - if you find knock with a certain cylinder you can retard by individual cylinders - sweet.
how do you graph knock by cylinder
Old Dec 3, 2009 | 07:12 PM
  #33
thesilverbullet's Avatar
there is already a knock templete setup that shows all the knock varables or you can create your own templete to graph whichever sensors.
you can right click in the graph area and select define templates for access via the options tab.
Old Dec 3, 2009 | 07:40 PM
  #34
JustinC's Avatar
yeah, but there is just a single knock sensor..how would it know which cylinder the knock is occuring
Old Dec 3, 2009 | 08:37 PM
  #35
Hondata's Avatar
Former Sponsor
Easy. If the ECU hears knock, it must be from the cylinder that is on the power stroke.
Old Dec 3, 2009 | 09:12 PM
  #36
nice - is that a built-in honda feature or a hondata programmed feature?
Old Dec 4, 2009 | 05:08 AM
  #37
JustinC's Avatar
ah, sorry, didn't realize this was a flashpro feature only
Old Dec 4, 2009 | 10:24 AM
  #38
I am loving the new flashmanager version!
Old Jan 29, 2010 | 07:35 AM
  #39
Gernby's Avatar
Former Sponsor
Originally Posted by thesilverbullet,Dec 1 2009, 08:34 PM
comparing the hondata stock map vs the toda map they retarded timing in 13 cells on the high cam and all others are the same.
two at 5900rpm in columns 9 & 10
two at 6200rpm in columns 9 & 10
three at 8000rpm in columns 8, 9 & 10
three at 82000rpm in columns 8, 9 & 10
three at 84000rpm in columns 8, 9 & 10
so i don't think you find much with timing adjustments
It's possible that I may be detonating my motor to death, but I'm gaining power from timing adjustments, and have even been able to lower VTEC to 3900 RPMs with gains because of it. Here is my timing curve and klnock retard compared to stock (blue). I'm not getting any knock counts either. Any thoughts? Should I be afraid?
FWIW, I am using 93 octane fuel with 1 step colder spark plugs, and my AFR is in the high 12's / low 13's depending on humidity. Atmospheric pressure is about 970 mBar. I discuss it more in this thread.
whiteflash
Apr 5, 2010 12:22 PM
bullet21
Jun 17, 2007 07:42 PM
mumbler
Jul 17, 2006 10:36 AM
kush only
Mar 30, 2005 07:29 PM
