Upstream O2 sensor AP1 facelift
AP1 dbw (drive by wire) and AP2 dbw use the same part number O2 sensor.
You can check the part numbers yourself on this UK site bellow, there is a small trick to show the correct Honda number though which is to remove _pfk from the link.
Correct https://www.lingshondaparts.com/hond...9&block_05=hcr
pfk numbers https://www.lingshondaparts.com/hond...9&block_05=hcr
I think there is some possibility that the Blueprint sensor you got is just not compatible.
So maybe start with new sensor and lets hope you don't have any other problem.
