V-AFC install question
Old Nov 25, 2013 | 10:05 PM
lopez14's Avatar
Default V-AFC install question
I picked up a vafc 1 today and it just came with the unit and extended harness. Now how in the world do I go about installing this thing? do I need a boomslang harness or some other kind? The only time I ever see people using a harness is with the vafc ii but I've yet to see one with the vafc i. Would I just hardwire it? Is there a DIY?
Old Nov 25, 2013 | 10:51 PM
Rays S2k's Avatar
Does that harness have plugs on the end of it
Old Nov 25, 2013 | 11:22 PM
lopez14's Avatar
No It's just split ends, here's a pic
Old Nov 25, 2013 | 11:40 PM
Rays S2k's Avatar
You can either search for a wiring diagram or buy a frog harness which is 100 times easier
Old Nov 25, 2013 | 11:53 PM
Rays S2k's Avatar
http://store.excelerateperformance.c...504&make=HONDA
Here you go this and it's just plug and play good luck
Old Nov 26, 2013 | 12:01 AM
lopez14's Avatar
Do those work for both vafc 1 and 2? Also are all those boomslangs the same thing as long as its for an s2000 or are they different? i.e. is a boomslang for a greddy emanage the same one as for the vafc?
Old Nov 26, 2013 | 04:50 AM
Rays S2k's Avatar
Yes it should work for both vafc 1 and 2
The boomslang are different depending on the year
And no they are not the same between the emanage and vafc
Old Nov 26, 2013 | 09:26 AM
lopez14's Avatar
Is there a way to just tap into my harness? I've seen those boomslangs get pretty pricy
Old Nov 26, 2013 | 10:04 AM
Rays S2k's Avatar
Yes you can splice into the harness you just have to find the wiring diagram and if in the future you decide to sell the vafc then you would have to attach all the wires again is a pain in the ass
PilotChris
Jan 31, 2005 03:27 PM
S2KEvolution
Oct 7, 2003 08:50 AM
s2quick
Aug 14, 2003 12:42 AM
VTEC Racer
Sep 28, 2002 07:07 PM
