VAFC
Old Nov 1, 2010 | 09:05 AM
abnormals2k's Avatar
Default VAFC
What are some actual #'s people are getting with simple bolt ons and a VAFC?
Old Nov 1, 2010 | 10:40 AM
Gernby's Avatar
Former Sponsor
A VAFC will net the biggest gains on a stock car. Once you start adding "good" bolt-ons, the gains from the VAFC will actually go down.
This is because a VAFC type piggy back uses the MAP voltage to alter fuel and timing. If you add good bolt-ons, the air / fuel mixture will become leaner and leaner, and your tuning margin for the VAFC will go down.
Old Nov 1, 2010 | 10:41 AM
Gernby's Avatar
Former Sponsor
That said, I made about +12 rwhp with just an AEM V1, test pipe, and VAFC type piggy-back in my '02 AP1.
Old Nov 1, 2010 | 12:00 PM
g35s200o's Avatar
so the apexi units such as vafc neo and vafc II can only remove fuel? these units cannot add fuel?
Old Nov 1, 2010 | 12:09 PM
urBan_dK's Avatar
Technically, they can add fuel. But the stock ECU won't like it since you will be altering the MAP sensor output to go above atmospheric, which will trigger a CEL.
Old Nov 1, 2010 | 12:36 PM
Gernby's Avatar
Former Sponsor
I think you can add 2-3% before the ECU will freak out. However, you might be able to add fuel everywhere with an FPR, then remove what you don't need with the VAFC. I've never tried it, but I can't see any reason why it wouldn't work.
Old Nov 1, 2010 | 03:15 PM
H22toF20's Avatar
Never liked the idea of a piggy back. Being able to tune fuel and timing separably is a must.
Old Nov 1, 2010 | 03:16 PM
urBan_dK's Avatar
Being a piggyback doesn't preclude having both. Example: Greddy Emanage. You can tune timing and fueling directly.
Old Nov 1, 2010 | 03:17 PM
urBan_dK's Avatar
There is a local guy s2000junky who does this very thing. Uses stock injectors with an 8 psi CTSC, trimming fuel with a VAFC.
Old Nov 1, 2010 | 07:24 PM
I dont have the $$ to go FI for a little bit so i thought a VAFC would be a good buy.. I'm running a AEM V2, Apexi 70mm catback, SOS 70mm test pipe.. so you think i will be able to harness about 12rwhp with what i got?
