VTEC and ignition timing?
Does the stock ecu automatically advance timing to make up for power loss caused by lower atmospheric pressure at higher elevations?
I wish we had a way to view the primary and secondary tables in the ap1 stock ecu to understand what exactly it's doing.
S2konroids, any further insight into this timing offset feature that you mention? Has anyone figured out a way to view/log accurate ignition timing through the EMU?
Also, Jake's OBD2 logged stock AP1 ignition curve may appear more advanced than normal due to the lower manifold pressure, but is there any reason to think the shape of the curve itself is inaccurate? Would a lower elevation/full manifold pressure curve look the same, just with less advance?
Originally Posted by gernby' timestamp='1339505326' post='21774725
[quote name='legend4life' timestamp='1339481944' post='21774360']
[/quote]
Ignition advance will increase as manifold pressure decreases, so there is an inverse relationship between fuel and ignition advance. On average, the shape of the IGN curve will be similar at different MAP levels, but the knock tables will cause it to deviate at high MAP levels.
I agree with both of you on most Dynojets. You can't get a good tune on most Dynojets unless your idea of a good tune only involves WOT. (Mine doesn't.) To me, load bearing dynos are awesome because they're a one stop shop and you can fully tune a car in a couple of hours or maybe half a day at the most. Note that Dynojet does make load bearing dynos and they're said to be fairly decent.
Tim
Tim
