What is your minimum TPS voltage?
Old Jan 24, 2012 | 05:47 PM
joefish1298's Avatar
Default What is your minimum TPS voltage?
Recently had problems with my 30-6052 and high sensor voltage readings. Unit has now been repaired by AEM.
Before I sent it to AEM I was reading a minimum TPS voltage of 1.04V, now the repaired unit shows a minimum of 0.32V.
Should this be reading even closer to 0 than it is, and is there any mechanical adjusment (cable, throttle body) that will affect the minimum TPS voltage?
Thanks.
Old Jan 30, 2012 | 04:10 PM
Thanks for the reply, I'm not sure of an event which caused my original sensor reading problems, but I don't think it was a single event as my sensor voltages slowly increased over a period of about 18 months (orig thread here https://www.s2ki.com/s2000/topic/864...ct-do-you-see/)
AEM fixed a semi burned out resistor, and suggested I might have a problem in my wiring harness, but an auto electrician has since given me an all clear.
So I just wanted to check that 0.32V was within the appropriate range for a correctly functioning 30-6052.
iDomN8U
Jan 20, 2013 08:50 AM
Kawasakivtec
Sep 6, 2012 11:52 PM
passmans2kny
Mar 6, 2012 08:21 AM
stevharr
Aug 29, 2006 07:36 PM
