Wheel speed sensor for cluster with AEM EMS V2
I’ve researched this on multiple forums and can’t find exactly what I’m looking for. The cd009 transmission I’m running does not have a output shaft sensor, therefore I’m trying to convert the signal from my front wheel speed sensor to a signal my cluster can read using the aem series 2. Can this be done? I’ve seen sources of people using the infinity to accomplish this but not the v2. The tacho is using LS7 by default but I’m wondering if I set the tacho freq in to T3 (vehicle speed) and tacho freq out to LS1 could I change the tacho m multiplier and accomplish this. I’m not sure if this will interfere with the stock tacho signal for rpm. If this won’t work my other option would be to get some sort of converter. Basically I just need a multiplier of around 2 to 3 times the wheel speed ppm.
Not sure if you may need something like this if you can't find the option.
https://www.dccdpro.com/product/vsspro/
tpolonyi
Jun 4, 2019 07:27 PM
Lainey
Apr 9, 2019 05:57 PM
works like a charm
