06 comptech sc is out
Originally Posted by Soul Coughing,Dec 1 2006, 08:22 AM
they say 8psi is the limit of the returnless fuel system... so i'm guessing a 7psi pulley could be done!
Originally Posted by Phillie,Nov 30 2006, 10:28 PM
Boxsters are weak anyways! Their resale value is almost as bad as domestic cars. So 355 at the crank means about 285 at the wheels since you loose about 20% through the drivetrain. $6500 for about 100 rwhp. About $65 a hp. BUT being carb legal is a HUGE Plus!
Grim, before you edited your post you had:
The crank is in the engine not at the wheel so any hp loss is lower than that figure.
I thinkit's you that has messed up their post.
If the engine is producing 310-320 at the crank (aka wheel)
I emailed them today cause the idea of the reflashed ECU interested me, simply because 1. the normal Hondata ECU raises redline and 2. the 04-05 Supercharger's peak hp comes at redline so even if there wasnt more power to be made after 8000 rpm, having some more revs avaliable after peak would make the car faster, even if its only like 300 rpms, (N/A ECU adds 600 rpms). Not to mention that there COULD be more power to be made (although I personally wouldnt risk it).
HOWEVER, the 06 kit does not raise redline and the power should be similar to the 04-05's.
I wonder if there is anyway Hondata will sell a 06 ECU reflashed just to raise redline with the supercharger kit. I think it would work wonders.
2.2 + 8300 to 8600 rpm fuel cut + boost =
But yes, turboing will probably produce more power.
