06 Turbo Questions
Old Apr 17, 2010 | 01:17 PM
Suzuka-S2K's Avatar
Default 06 Turbo Questions
I have a precision 50 trim turbo from another car that I sold and I want to run it on my S2k. going to run Flash Pro for management. I ordered everything I need basically for the car except a fuel pump. Injectors, engine management, manifold, wastegate, BOV, etc...etc... Is it true that if you are making less than 350 whp you dont need a walbro pump??? Also I ordered a generic intercooler piping kit and was wondering what you guys are doing for the IAT sensor. Do I need to have a sensor bung welded to the pipe for it and also do I need to do anything to the map sensor??? I had read somewhere that on the 04-05 cars you had to use some adapter for the map sensor.
Thanks
Old Apr 17, 2010 | 01:23 PM
daicacharco's Avatar
One of the members here on the forum had issues with not upgrading the fuel pump with his kraftwerks kit and blew his motor due to not enough fuel. Atleast that is what he told me.
Old Apr 17, 2010 | 01:29 PM
Vi3tBoy's Avatar
fuel pump is 90 bucks
Why not spend it to be safe?
Old Apr 17, 2010 | 01:34 PM
dragtek's Avatar
^ very true
Old Apr 17, 2010 | 01:43 PM
Suzuka-S2K's Avatar
Ok so definately going to get a fuel pump then. But what about the IAT and the map sensor??
Old Apr 17, 2010 | 03:51 PM
Blucky87's Avatar
stock AIT shoud be fine and assuming the stock map sensor is 1 bar it should be good for 14 psi but most people upgrade the map sensor to 2-3 bar anyway. just buy a GM 3 bar and wire it in. or buy SoS's plug and play
Old Apr 17, 2010 | 04:20 PM
Suzuka-S2K's Avatar
So will i be ok just welding a sensor bung to the intercooler pipe for the iat sensor?? What do most of the other guys do???
Old Apr 17, 2010 | 04:32 PM
DFWs2k's Avatar
doesn't the ecu already read iat ?
Old Apr 17, 2010 | 04:35 PM
Blucky87's Avatar
well I guess you could move it if thats what you mean... would have to ask someone else. Whats wrong with leaving it where it is?
Old Apr 17, 2010 | 04:48 PM
Suzuka-S2K's Avatar
Well on the 06 and up cars the IAT sensor is on the rubber intake tube down by the air box.
