10 psi gt35r ?
Old Jul 7, 2009 | 06:15 PM
aecampeau's Avatar
Default 10 psi gt35r ?
just like description said i just put a custom kit i made by my self on my AP1 ..
by the way we have alredy make allot of turbo honda succefuly...
the turbo is a gt35r .82 ar custom top mount 3 '' dp, 3" cut out...
aem 1052 .. 1000cc pte, 2.5 ic piping ......
i put down 310 whp ans 200 tq i was wondering if the vtec not giving is potentiel power ...
with the dyno sheet i should be more close to the 340 whp at least .... any body know ??
Old Jul 7, 2009 | 09:43 PM
neeman77's Avatar
The big variable is your tune it is very hard to say what your car "should" have. Did you ever do a baseline run on that dyno?
Old Jul 7, 2009 | 10:58 PM
DeadZero's Avatar
this could be important too
also do you still have the stock cat & exhaust?
with those restricting flow you should be still at about 350+ with that turbo. also what kind of manifold do you use?
Old Jul 7, 2009 | 11:13 PM
AusS2000's Avatar
Also, if 300-400hp is you goal wouldn't you be better off with a GT30?
Old Jul 8, 2009 | 01:10 AM
N1Concepts's Avatar
I think if you posted your dyno sheet w/ A/F ratio, we might have a better idea.
I have a similar setup, but on 8 psi, this is with a 3" exhaust, no cat, through a magnaflow muffler. It's a full-race kit with the full-race GT3567R. at 8 psi we made 340whp on a DynoJet 224x
Old Jul 8, 2009 | 05:24 AM
aecampeau's Avatar
i put the 35 because i alredy have it in the shop... my manifold is a custom log... i try to post my dyno sheet today ... and i run a 3 in cut out so there is no restrection froom my cat and exhaust ...
Old Jul 8, 2009 | 07:35 AM
Spec_Ops2087's Avatar
Depends on the dyno itself and the tune.
I only made about 370rwhp @ 10psi IP log manifold and a dynojet
Old Jul 8, 2009 | 07:36 AM
camuman's Avatar
need a baseline of your car to see whats up. mustangs rely on the weight you put in to calc the hp number i believe, what weight did you put in?
with a log mani, i would guess 325-340 is what you should be at on that dyno at 10psi.
Old Jul 8, 2009 | 09:30 AM
aecampeau's Avatar
the made 198 whp on the same dyno .... and we put 3125 lbs... i dont said the car make no power just curius about the big power diff before vtec and not to much gain in high rpm ...
Old Jul 8, 2009 | 11:34 AM
DeadZero's Avatar
what?
the car makes no power but has a big power difference before vtec and doesn't gain much in higher rpm?
post a dyno sheet LOL
