100% Duty on ID1000
good to know that 12-14 psi on the novi1200 = 400whp as thats where i am. i will be pulling my pan next oil change to check my baffle and replace rod bearings my timing above 7k is 17 degrees timing hope thats not too much . in my sig i have a pump install write up it might help you though i am ap1 with ap2 drive train
As far as your timing goes, I run 17 around 7k and 16 around 8k and 15 at limiter. I made power with an extra 2* in there, but right above that was when it started pulling timing due to knock retard. So I backed off a couple degrees
I need to drive my car to the tuner next week. Can I put gas in my car with E85 tune and "granny-drive" to the tuner?
Or is it better to use some sort of base tune to drive to the tuner? Is there any one in the Flashpro?
If I take it easy i guess that my map-sensor will adjust the fuel?
Got my car tuned yesterday.
352whp and 300wnm happy with the result and the car pulled great.
Saw 360whp+ but that was with to aggressive timing so we backed of a bit.
Today when i drove the car had afr 10.3 under WOT and that is not how we tuned it.
Tuned about afr 12-12.5
Why is this? Just got from good to bad over night.
I got some misfire today as well under low trottle. Dont understand?!
Hows the temperature outside compared to when / where you had it tuned? misfire at low throttle sounds like a tune issue as well, what were the AFRs when that occurred?
Are you sure you had the e85 completely out of your tank? If you had some kind of mixture in there still of pump and e85, when it finally cleans out to straight pump, you're gonna be running rich
Im on the same tank of gas as when I tuned it. So that will maybe happen but not yet, i guess.
The temp outside was warmer yesterday than when I tuned it.
The missfire was about AFR 15 and LOW speed with almost no throttle at all.
This is so weird... Can someone send me a pic of the fuel pump install on a AP2?
I will take a pic of mine when I get it out, but i don´t think that´s the problem.
Is it the pump that have a problem with the returnless fuel system?
BTW, this is the dyno. The car pulled without problems on the dyno:
image url upload
image url upload
I assume this is on the AEM EMS? Its surprising how much temperature effects the AFR but I wouldn't expect it to make that much difference. The misfire at low throttle happens where there isn't enough fuel at high vacuum positions of the map. What I do personally is add abit of fuel in those areas and then let the wideband feedback trim it back. That way you have the fuel when you touch the throttle but it wont run rich for ages and ages as the o2 will trim it back.
