100% Duty on ID1000
Old May 10, 2016 | 10:01 AM
Erajk's Avatar
Default 100% Duty on ID1000
Have the following setup:
ID1000
Returnless AP2
Dw300 fuel pump
SOS Spercharger Novi 1200
Upgraded heat exchanger
Stock exhaust with decat
4bar mapsensor
NGK BKR8EIX
Competition Clutch Stage 3
Im hitting 100% duty on E85 at 7600rpm.
Max psi is 9 at about 8 000rpm
I think that this is wierd? Or is it normal?
I have a smaller pully home and now im thinking about installing this and go for 13psi on gas.
Please help me!
// Erik
Old May 10, 2016 | 10:07 AM
KaNgArOo's Avatar
That's weird. Maybe your fuel pump isn't hardwire to your battery with a relay.
Old May 10, 2016 | 10:14 AM
Erajk's Avatar
It is, but something have to be wrong....!
Can someone send me a picture of the hardwire-install?
Old May 10, 2016 | 10:25 AM
King Tut's Avatar
My ID1000s hit 100% duty at around 7000 RPM and 15 psi on E85 as another data point.
Old May 10, 2016 | 10:34 AM
Erajk's Avatar
Thx man!
I will check my relay and hard wire again, so i didnt f@#k it up.
It sounds like i should get away with 10psi and E85 on my setup
Old May 10, 2016 | 11:32 AM
yamahaSHO's Avatar
Run a bigger fuel pump (hardwire it) and bump the pressure.
Old May 10, 2016 | 11:39 AM
Jin_SK's Avatar
Returnless AP2
There's your problem. Do you have a gauge on your fuel rail?
Old May 10, 2016 | 11:45 AM
Erajk's Avatar
I don´t have a gauge on my fuel rail
Hmmm.. I think I will tune it on gas instead... Then I cant be low on fuel?
This is my hard wire. Cant be wrong?
photos upload
Old May 10, 2016 | 11:46 AM
yamahaSHO's Avatar
Good catch... I never pay attention to the returnless part.
Old May 10, 2016 | 12:16 PM
Jin_SK's Avatar
Well, you'll certainly have more headroom on regular gas, but ultimately you'll want to do a conversion to a return style fuel system. If you're set on the ID100s then you'd need to bump up your fuel pressure but you can't do that effectively on the stock returnless.
