10psi Pulley Question!
Old Jun 16, 2005 | 07:58 PM
EriS2k's Avatar
Default 10psi Pulley Question!
Yesterday i Installed a Front Mount Intercooler , 550RC Injectors and the Science of Speed 10psi Pulley! And i'm not Getting 10psi!! Like WTF>?
My Boost Meter Keeps Showing 7.35 Psi?
Whats Happening!
Yes The Belt is Tight!
Old Jun 16, 2005 | 08:10 PM
Slows2k's Avatar
Sounds like a big pressure drop accross the front mount. swap back to the Comptech intake tube and see if you've got your boost back.
Old Jun 16, 2005 | 08:28 PM
SIIK2NR's Avatar
Shouldn't be any pressure drop from the front mount... and it's an aftercooler correct?
What are you using to tune?....EMS?
Old Jun 16, 2005 | 09:12 PM
xviper's Avatar
A front mount intercooler has extra volume that needs to be compressed. More volume, less end pressure. This usually drops about a lb. or 2, so putting the original intercooler may get you back that drop. The rest may be due to poorly sealed connections between the supercharger and the throttle body. There's a lot of joints and connections and welds along the way.
"Intercooler" and "Aftercooler", although they have their specific definitions, have been used interchangably for a long time. Using either conveys the same connotation. The main difference is if it's "air/air" (front mount in this case) or "air/water" (stock Comptech or Vortech) type.
Old Jun 16, 2005 | 11:23 PM
bgbfflochp's Avatar
I really don't know. Honestly, I had a 9lb pulley on mine with a front mount, and only got 6lbs of boost. I had the loss of boost narrowed down to the intercooler but still couldn't find any leaks. I thought 3lbs of lost boost was a little too much, (I had always heard to expect 1lb or 2lbs tops). I bought/installed the comptech aftercooler and now my max boost gets up to 8.6lbs. I've never even looked back. I honestly think it's the front mount. It was for me. If you find it to be anything else, please let us know. I'd be interested to see.
Good luck,
Dave
Old Jun 16, 2005 | 11:59 PM
73Zero's Avatar
Eri_S2k is using a custom front mount intercooler setup instead of the Comptech aftercooler...which would probably explain the loss in boost, due to pressure drop...
Old Jun 17, 2005 | 12:36 AM
BLOWNJROCK's Avatar
damn i'm running 5.0 psi with stock oulley on my fmic
Old Jun 17, 2005 | 02:25 AM
S2000_Europe's Avatar
I remember that bigpurp dyno'ed his car with stock Aftercooler ( Vortech) then he dyno'ed with the fron mount and got almost the same numbers
you should PM him
Old Jun 17, 2005 | 10:23 AM
EriS2k's Avatar
Yes the Pressure Drop is because the BIG Front Mount Intercooler!
Need a 14psi Pulley! where can i find it?
Old Jun 17, 2005 | 10:33 AM
APEXSEAL's Avatar
Si quieres verificar para estar seguro, dile a Jo que te conecte el reloj de boost ANTES del intercooler. De esta manera sabras exactamente cuanto boost estas perdiendo por cuasa del intercooler.
