2.5>>>3" exhaust upgrade options
Old Dec 15, 2007 | 04:16 PM
05TurboS2k's Avatar
Originally Posted by Asura,Dec 15 2007, 03:01 PM
3" Dual
You could upgrade your DP to a true 3" as the 2.5" is definately a restriction with the 2.5" DP. A 3" system might give you the gains you are looking for with out changing the DP too.
What sort of HP are you currently making at 7.5 psi?
ok.... you lost me here....
I understand that out of the turbo gas still wants to continue to expand a bit, thus the pipe that exits the turbo side will always be 2.5...but will instantly go to 3" out of the turbo, THEN it stays 3" the rest of the way out right.
You said upgrade the DP to 3" from my current 2.5....that makes sense
a 3" system might give me the gains im looking for with out chaing the DP too???
You figure just bolting a bigger pipe 3" to the 2.5 DP? That means the gas would have to still be expanding at the end of the DP.... do you think that'd be the case? I'd imagine it'd be cooling by that time.
7.5psi is making 300whp.
Old Dec 15, 2007 | 04:22 PM
05TurboS2k's Avatar
Originally Posted by Spec_Ops2087,Dec 15 2007, 05:16 PM
I think you could run at LEAST 15psi on stock compression with race gas considering I ran 10psi no problem on stock compression with 93 octane.
ya he said 12 would be making it way safe. and ya 10 is the most ive heard of on a pump with a really safe tune.
wojtekj1977
May 4, 2014 05:32 AM
bottleboy
Aug 11, 2013 09:01 AM
Competitor9
Aug 10, 2010 06:47 PM
daleangelfan
May 4, 2009 10:51 AM
sbrodacz
Feb 6, 2009 12:55 PM
