Donut Gasket 3" Exhaust?
Old Aug 7, 2010 | 11:33 PM
Competitor9's Avatar
Default Donut Gasket 3" Exhaust?
So I have the 3" downpipe off my turbo to a 2 bolt flange. Running a HKS 75mm single and about to get an Asura 3" TP.
My question is do I need a set up like the stock one with springs and a donut gasket. My thinking is that I would need some sort of shock absorbtion from the exhaust moving around, because I don't want the stress of movement transferred onto the turbo.
The exhaust is just hanging on the rubber hangers so once it's all fastened together the only thing totally restricting the exhaust's movement would be the downpipe bolted to the back of the turbo. It just doesn't seem good am I worrying too much or do I need something like a donut gasket and spring bolts from the test pipe to the downpipe to absorb motion?
Old Aug 8, 2010 | 12:22 AM
TRBOKEV's Avatar
You need to have a flex pipe added.
Old Aug 8, 2010 | 06:54 AM
where and why
Old Aug 9, 2010 | 06:51 PM
If i put a flex pipe on where am i putting it on the downpipe? Or somewhere between the exhaust and the test pipe
Old Aug 10, 2010 | 03:34 AM
chef-j's Avatar
If you are going to put it on exhaust pipe, make sure it won't hit ground. It can scrap on ground and cause a leak in future.
Old Aug 10, 2010 | 06:47 PM
all taken care of slipped it in the down pipe and no more worries
S2KCHRIS305
Oct 12, 2014 06:35 PM
macdaddies911
May 22, 2014 06:49 AM
stage3
May 31, 2009 10:36 PM
scottieboy561
17
Dec 14, 2008 11:59 AM
nastinupe1
Mar 20, 2003 11:59 AM
