2004 s2k turbo problems
Old Feb 7, 2007 | 01:42 PM
newformularedbullet's Avatar
Thumbs down 2004 s2k turbo problems
Hello, I have a 2004 s2k. I have recently added a turbo kit, stage 1. I am having a problem with my blow off tube gasket blowing out, any suggestions? Thanks Dick
Old Feb 7, 2007 | 01:43 PM
Enthralled's Avatar
maybe you should post this in the FI section.
Old Feb 7, 2007 | 03:23 PM
timg's Avatar
What turbo kit? What BOV? What gasket?
Usually, when a gasket blows out it means that the surfaces weren't flat. You can always try coating a new one with copper RTV gasket maker.
Tim
Old Feb 7, 2007 | 04:57 PM
Tyraid2K's Avatar
sounds like risky busines tim
Old Feb 7, 2007 | 05:37 PM
JDMKID35's Avatar
Banned
this is a joke
Old Feb 8, 2007 | 02:55 AM
jbotstein1's Avatar
I blew out 3 wastegate gaskets when I had the Ultimate Racing kit. Is that what you're running?
Old Feb 8, 2007 | 08:23 AM
RacerXI's Avatar
I believe he meant wastegate. Check to make sure the flange on the manifold is not warped.
Old Feb 8, 2007 | 05:06 PM
timg's Avatar
If it is the WG, try two things.
1. The Turbonetics wastegate gasket. It has extra thickness around the sealing area. It seems to work MUCH better than the Tial 38mm gaskets.
2. Lots of copper RTV. Yes, it does work on even the WG gasket.
Tim
Old Feb 9, 2007 | 02:07 AM
yeah, it's the waste gate. I've tried rtv. I think I might have a metal gasket made for it? It's an inline pro
Old Feb 9, 2007 | 02:31 AM
Reborn56's Avatar
i was actually having the same problem with blowin gaskets, ended up rethreading my manifold, the screws werent going down all the way.
After that no more blowing gaskets.
Marcus
