2nd Attempt - CTSC FMIC
Old Feb 14, 2008 | 09:14 AM
nightcrawler7188's Avatar
Default 2nd Attempt - CTSC FMIC
i'm getting my hands on General Kratos' old piping kit he used to fit a FMIC with his CTSC. he had NO boost loss and was running 5psi with 2.5" piping and a Precision 600 intercooler. i'm running 6-7psi right now and i was wondering if the 2.5" piping with the Precision 600 would work for me as well. basically, do you need bigger piping/bigger intercooler for only 1-2psi more boost?
thanks
Old Feb 14, 2008 | 12:14 PM
CourageOO7's Avatar
You're fine...7 psi is a low boost setup and the precision 600 is overkill for this setup. That being said, you'll have plenty of headroom for more boost!
Old Feb 14, 2008 | 12:57 PM
CU Nick's Avatar
Is it possible to rotate the charger to the passengers side to eliminate that U-bend? If you can it might flow a bit better.
Old Feb 14, 2008 | 02:51 PM
it is possible to do that. that was how the last kit i had made was set up. but i don't like having the filter right behind the radiator fan. also it's very tricky to get the piping out of the headlight hole/around the headlight bracket/back down and around to the fmic without getting too close to the wheel.
i plan to just leave it the way it is in the picture cause General Kratos had no problems with it. i'm tired of trying to be a pioneer and running in to problems
Old Feb 14, 2008 | 02:53 PM
thanks! what i was wondering if having an intercooler that's too big would lose any boost because it's more space to push air through.
Old Feb 15, 2008 | 11:48 AM
TRBOKEV's Avatar
This setup looks very nice and should work well. Keep us posted please.
Old Feb 15, 2008 | 01:04 PM
CU Nick's Avatar
Ah, good deal. I was just curious. Thanks for the info!
Old Feb 15, 2008 | 03:11 PM
duff0000's Avatar
Let us know how it turns out!
Old Apr 6, 2008 | 11:37 AM
duff0000's Avatar
updates?
Old Apr 6, 2008 | 11:53 AM
i ended up not buying the piping kit because after further research and talking to more people, it turns out that this fmic kit actually did lose that much boost.
