3 bar map sensor (Recommendation)
Old Apr 6, 2011 | 09:35 PM
  #21
Mijae007's Avatar
i actually have to sand down some of the plastic on the sensor to fit the oem plug. did anybody else have this problem? its technically not a true plug and play with the omnipower map 4bar for 06up s2k
Old Jul 25, 2019 | 12:14 AM
  #22
RolanTHUNDER's Avatar
Sorry to bump this.
How about the K-tuned sensor? Good, bad? Will it integrate well with an AEM EMS V2 for AP1?
On that note, what would happen if you ran a 3 or 4 bar aftermarket MAP sensor with your stock ECU?
Old Jul 25, 2019 | 02:45 AM
  #23
pizzai69's Avatar
Stock ECU can only use stock map sensor. Any other range of pressure will not be compatible.
Old Jul 25, 2019 | 04:27 AM
  #24
OK thanks for the info
Old Jul 26, 2019 | 09:55 AM
  #25
mys2k3's Avatar
AEM also has a map sensor that works well, 3.5 bar and 5 bar.
Old Jul 28, 2019 | 09:58 PM
  #26
3.5 bar? That's interesting. Thanks for the info, I'll look it up
Alexander Startsev
Aug 29, 2016 01:31 PM
whitedxi
Dec 11, 2014 11:16 PM
TCS2K
May 18, 2003 12:52 PM
