3mm Copper Head Gasket
Old Dec 30, 2012 | 07:05 PM
WRX2S2K's Avatar
Default 3mm Copper Head Gasket
Hi Everyone,
I'm planning on turboing my S2000 next year. Would it be worth it to try a 3mm copper head gasket to lower compression? I know the conventional head gaskets aren't reliable, but I assume a metal gasket would be better? Or would lowering compression with this method start messing with quench and not be worth it? I'm looking for about 500 horsepower on pump gas.
Thanks!
Old Dec 31, 2012 | 01:47 AM
r_holguin's Avatar
Why would you do that? You'd have to run more psi and you'd have to be worrying on whether or not your hea gasket Is holding up or not. There's a few s2000's making 500 on pump gas with out head gasket replacement on stock compression. Just my 2 cents your car though.
Old Dec 31, 2012 | 09:49 PM
AusS2000's Avatar
I use the SCE 2.4mm head gasket.
I've had plenty of head gasket problems previously but they were all tuning related and not a problem with the gasket.
LAE
Nov 25, 2018 04:45 PM
Sideways
Mar 6, 2015 06:15 AM
WRX2S2K
Jan 2, 2013 10:02 AM
slociviccoupe
Mar 26, 2009 04:43 PM
SuzukaS2K
May 16, 2003 10:00 AM
