3mm headgasket users
Old Oct 15, 2006 | 06:18 PM
Kwando's Avatar
Default 3mm headgasket users
i will be doing a 3mm headgasket install this winter. i understand that NO ONE has sucessifully used ARP headstuds with the 3mm headgasket, so i will prob be using stock studs.
i am confused about the cam pin adjustment. does anyone have a pic of this?
any help is appreciated.
Thx
Old Oct 16, 2006 | 04:07 AM
OGPackin's Avatar
Thx
Iv been using a 3mm HG with ARP headstuds for 6 months or so....
Sorry! i dont have a pic of what your asking for...
Old Oct 16, 2006 | 04:40 AM
j_c_a's Avatar
Don't have a pic either, but I'm not sure where you heard that you can't use ARP headstuds w/ it. I'm using them just fine and don't really understand why anyone would think you couldn't.
Old Oct 16, 2006 | 06:36 AM
geists2k's Avatar
Thx
Uh, I'm using ARP studs with the 3mm gasket and have about 3K miles, some of those pretty hard, and two tuning sessions on the dyno without a single problem.
Don't know who the "NO ONE" is, but maybe the people like me just haven't posted anything with regard to this because we haven't had any problems at all.
I do know this -- the shop that installed the gasket said that it is very important to use the proper moly lube and proper torque techniques when installing any head gasket whether you use studs, a 3mm gasket or whatever.
Now my only problem is running out of injector at 16lbs. of boost at around 432whp/295lbs.
Old Oct 16, 2006 | 10:44 AM
passmans2kny's Avatar
i will also be running the 3mm with the arp studs, where did u hear no one was running this?
Old Oct 16, 2006 | 06:05 PM
Kwando's Avatar
let me rephrase... i've read that alot of people are having problems with that combo... sorry for posting the wrong information... what headstuds did you guys order?
any more info about that cam pin mod that is needed to run the 3mm HG...
thx for the help so far...
Old Oct 16, 2006 | 06:25 PM
Phillie's Avatar
This is what I found.
https://www.s2ki.com/forums/index.php?showtopic=269571
lns2k
Sep 21, 2008 11:31 AM
EriS2k
Aug 2, 2007 09:47 AM
doctornick
May 17, 2007 01:11 PM
