3mm hg install
Old Sep 29, 2010 | 10:27 AM
passmans2kny's Avatar
Default 3mm hg install
so i will be installing my second ip 3mm hg this weekend, i am going to use a ip 3mm metal spacer with honda outer layers, i wanted to know if i should use copper spray or not, i see some saying use it and others saying not to, whats the benefit of the copper spray? ill be using moly lube to 90ft/lbs also. also any tips from people who have their hg lasted a long time would be appreciated.
thanks
-matt
Old Sep 29, 2010 | 10:33 AM
o'malley_808's Avatar
I didnt use copper spray, cleaned the holes for the studs very well (they usually fill up with oil when removing the head, Also put hondabond/rtv on both sides of the hg around the timing chain housing.
Torqued to first to 60ft/lbs then 90ft/lbs with ARP lube as told by calling arp tech and inlinepro...
so far so good with about 5000miles @ 26psi daily
Old Sep 29, 2010 | 11:45 AM
siadam's Avatar
I wouldn't and don't use it.
Old Sep 29, 2010 | 11:54 AM
MADjdm's Avatar
I didn't use copper spray on mine and it's holding up fine so far
this recent thread has good discussion on the torque specs/molly use
https://www.s2ki.com/forums/index.ph...ic=819055&st=0
Old Sep 29, 2010 | 12:19 PM
camuman's Avatar
i agree, but thing is for him to do it any other way will cost a lot more money and time. he lasted a long time on that thing, so at least do it once more and then decide where to go from there.
Old Sep 29, 2010 | 12:27 PM
hondabond it is, my mechanic friend also said dont use it and to just use hondabond. thanks guys
Old Sep 29, 2010 | 01:04 PM
1SlowSi's Avatar
Use hondabond on what parts?
Old Sep 29, 2010 | 01:09 PM
Spoolin's Avatar
Around the timing chain cover. It states it in the Honda Helms manual.
Old Sep 29, 2010 | 01:37 PM
D1sclaimer's Avatar
Old Sep 29, 2010 | 02:07 PM
Soul Coughing's Avatar
i have used copper spray on one headgasket, and then two without. Both gaskets lasted the same amount of time.
