5.5bls., 7lbs., 9lbs. ? PLEASE HELP!
Thanks for the info. If you can let me know what the total cost was for your tune injectors and EMS. I will probably take my car to Warren as well if you get good results.
I am very happy with the 7pound pulley. But I will eventually move up to the 9pound once I get the injectors and EMS.
Since you are getting your car professionally tuned with a stand alone EMS I think you are ok as far as wear and tear goes. There are people on this board who have been running their 7psi pulley with just the standard comptech FMU like me and have had no problems. But I don't recommend it. The route your going is much safer and will yield better results.
Of course the 9psi pulley would put more wear on your engine and S/C but it all depends on how you drive it.
I'll tell you one thing though your gonna need a clutch. If you haven't thought about upgrading you should start.
Josh
Josh
One more thing, you were asking about wear on the high compression engine. Just to put things in perspective, Ultimate Racing has a turbo kit out running 7pounds of boost and as you probably know turbos are at full boost at around 5K rpms on the S, dependant on the size of the turbo. If they can run their S reliably which they have as a daily driver. I don't think you should have any problems with the 9pound pulley on the S/C, since your upgrading your injectors and ECU.
There are others on this board that have run their UR turbo kit at 9psi reliably with no other upgrade just tuning.
Like others have said, you'd be ok just slapping that 9pound pulley on there.
Originally Posted by nsxinsac,Mar 7 2005, 10:52 AM
still be healthy. Also, I should not have a problem going with the 9lbs. pulley later if I'm not happy with the 7 since I'm doing the injectors and AEM ecu. My only cost at that point should be the $150 9lbs. pulley and tuning time. Also, before I run high boost and chance my motor, I would like to have the cash set a side for a new motor built for boost.
I strongly belive that the 9lbs pulley is quite safe *with proper tuning* and with an EMS.
I'd put the $500 towards a high boost motor buildup at a later date, but again, that's me.
Originally Posted by nsxinsac,Mar 7 2005, 11:48 AM
Also, are you pleased with the 7 psi. pilley or would you recommend the 9psi. pulley or is wear and tear on the high compression motor a issue?
Originally Posted by FF2Skip,Mar 8 2005, 07:11 AM
Why 650cc injectors for 7lbs of boost? That's way overkill, no?
Added: Here's a link to injector calculations.
Originally Posted by Doss,Mar 8 2005, 11:30 AM
Yes I think that's a bit high but its ok the duty cycle will just be lower. And I'm guessing they are probably going to leave out the high pressure fuel pump and comptech FMU.
That comes with the standard sc kit.
Originally Posted by Infidel,Mar 7 2005, 01:24 PM
The only issue with running higher boost on a high compression motor is detonation. If you're not detonating, you are safe.
Originally Posted by FF2Skip,Mar 8 2005, 08:59 AM
I'm by no means a knowledgeable person on these matters, but simply going larger just makes tuning more of a hassle, no? No HP fuel pump?
That comes with the standard sc kit.Take a look at some of the turbo kits out there, they do not require a high pressure fuel pump or FMU. They come with larger injectors and either AEM EMS or Greddy E-manage.
I know that the UR kit does not require an upgraded fuel pump. Since the kit comes with larger injectors and an e-manage.
But the rev-hard kit does require the high pressure pump since it runs on stock injectors.
I think some of the turbo guys can clear this up for us... Kane? Or maybe even Sideways since he's running a large amount of boost I bet he threw out the Comptech FMU and went all stand alone.
