613/407 stock block e85
Old Sep 8, 2012 | 10:54 AM
  #31
p0staboy's Avatar
is it safe at that power level? Shouldn't the headstuds atleast be upgraded?
Old Sep 8, 2012 | 10:57 AM
  #32
passmans2kny's Avatar
Old Sep 8, 2012 | 10:59 AM
  #33
hes only at 20 psi, seems to be working fine so far, and other people have ran more on stock head bolts, I dont see it being an issue until he wants more power
Old Sep 8, 2012 | 11:05 AM
  #34
sata3000's Avatar
Engine bay looks good
Sent from my Galaxy S II using Tapatalk
Old Sep 8, 2012 | 11:10 AM
  #35
neoleooo's Avatar
Originally Posted by passmans2kny
Originally Posted by neoleooo' timestamp='1347094568' post='21996832
[quote name='sohc_mshue' timestamp='1347072131' post='21996495']They are too small at that power level. I have maxed them out on a dynojet a bunch of times around the 580-600whp range on e85.
My ID 1000 maxed out at only 540 on E85 on the dyno pack. im only running one 340 pump. you think this is the reason why its maxing out at only 540?
what was your base pressure, duty cycle? jeff was saying these 340s dont like high pressures, so he didnt go above 70-75
Originally Posted by gettin it
Dam! Nice. Thats a 2.0 motor right? What size exhaust?
yes 2.0 motor unopened, open downpipe, he intends on making an exhaust asap, and I will be getting one from the same guy as well
[/quote]
my fuel pressure i believe is at %55. duty cycle is %100.
Old Sep 8, 2012 | 11:36 AM
  #36
I wouldnt run injectors at 100% duty cycle, jeff wasnt comfortable going over low 90s really
Old Sep 8, 2012 | 11:47 AM
  #37
bobbyrandolph440's Avatar
Jeff I hurd is a really safe tuner he likes to make power just wants to with all the rite parts
Sent from my DROID RAZR using Tapatalk 2
Old Sep 8, 2012 | 12:08 PM
  #38
I'm no tuner so I'm not positive about running 100% duty cycle on the id1000s, but it just seems like a bad idea to run anything maxed out all the time
Old Sep 8, 2012 | 09:18 PM
  #39
neoleooo's Avatar
yes that's why we lower the boost from 15psi to 13psi. duty cycle is still high though. thinks it's aroung the %90's. I'm waiting on some Deatcshwerks 1300cc injectors. hopefully those injectors will be good for 550hp at 16psi. do you think fuel pressure at 55psi is low?
Old Sep 9, 2012 | 05:52 AM
  #40
Originally Posted by Evans Tuning
Base pressure was set to 75 psi. At 75 psi ID 1000's flow approximately 1300 cc/min, or about 30% more flow compared to stock base fuel pressure (43 psi). In general e85 takes about 30-40% additional fuel flow depending on the % gas content (some stations have e70 or as high as e90). I typically see about 600 whp on ID 1000cc's/single 255 or 340 lph pump on race gas around 90% IDC. Mathematically the increase in base fuel pressure just offset the 30% increase in fuel flow through the injectors with e85.
I have at least 20-30 s2000s running around in the 600 whp power range on 100% longblocks that have never been opened up. Headstuds are a good idea if you have the engine apart, but stock they are extremely strong. I do not have issues lifting the head, blowing gaskets, etc at all.
In general you dont want to run any injectors over 90% IDC long term. I like to leave some available fuel for IAT comp table to make adjustments in the colder air.
So at 70 psi all is good on idle sorry to bring up again but u are the man to ask
