6266 gen2 expectations
You should see 650-700hp depending on how aggressive the tune is and the dyno. Fuel is going to be your limiting factor. You have the perfect size lines but... I would ditch the DW1500`s for some ID2000 and add a bosch 044 inline fuel pump with the walbro in-tank still. While youre at it I would just do a good -10 AN fuel rain and good adjustable FPR so you can run 100psi base fuel pressure. Do those things and you should be able to make 800whp with ease. The turbo and motor will support 800whp range if the fueling system can support it.
Also agree that 600 will not be a problem.
I'll stay with my set up for the moment to see the max of it
But will keep in mind of what you suggest!Appreciate that!
How much boost are you running?
Better? That's not my car nor am I affiliated with them, Rob is a friend and shared their 6266 gen2 results with me.
We also have a local car that runs in the FIS class that knocked off a 9.1 @ 167mph in an EG chassis on a B series motor.
http://www.precisionturbo.net/Street...-CEA%C2%AE/567
